Question about PaceMaster Bronze Basic Treadmill
I have a Pacemaster ProSelect and it squeaks. How do I fix
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
My treadmill no longer asks me for my weight, and I'd like to reset it.
go to reset. Turn off the power and reset the button too. Try again.
After that RUN the software calibration for easy diagnose, troubleshooting and fix it.
Happy New Year. God bless you
Jan 01, 2013 | PaceMaster ProSelect Treadmill Incline...
Treadmill no longer asks me for my weight, and I want to reset it.
try to turn off the machine. and reset the button and try again.
Happy New year. God bless you
PaceMaster ProSelect Error Code 31
mean defective lower PCA or upper PCA, try to tight any plug or connector or ribbon cable, However RUN the software calibration for easy troubleshooting , and fix it.
Go under the hood motor, and follow the step how to enter in the s. calibration.,see the block diagram attached.
God bless you
Nov 12, 2012 | Exercise & Fitness
PaceMaster Bronze Basic Treadmill Logo
41 people viewed this question
Top PaceMaster Exercise & Fitness Experts
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Electro Med Services...
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
