Question about Kitchen Ranges
Syntax micro torch lighter ignitor
Ignitor don't work
SOURCE: Similar problem but ignitor replacement did not fix mine
try the gas valve behind the storage drawer. it may be closed. that was my problem.
Posted on Aug 25, 2008
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
meBNme
  • 334 Answers
SOURCE: Gas Burner ignitor is not working
Yes it should be an easy fix.
Ignitors simply go bad from time to time.
If you have a meter you can check to see if you have voltage going to the ignitor. If you do, and it isnt trying to ignite, replace the ignitor.
If you have no meter, ignitors are usually less than 30 bucks so you will not be to much in the hole by just replacing it.
If you lift the cover to access the ignitor, it should be held in by two crews, the gas tube, and a wire to the flame sensor.
Make sure you turn off all gas and electric before disassembling.
You can find ignitors at your local appliance parts supply house.
All you need is the model and serial numbers.
Posted on Dec 27, 2008
SOURCE: Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Posted on Jun 18, 2009
  • 222 Answers
SOURCE: Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Posted on Jun 23, 2009
BROILER HAS NO REGULAR IGNITION DESPITE THE FACT THAT THE VALVE AND IGNITER ARE FINE AND BROILER AND ORIFICE IS IS CLEAN. GAS PRESSURE AND FLOW IS FINE. ONCE LIT (MANUALLY WITH A LIGHTER) THE FLAME W
How do you know the ignitor is fine? The ignitor for the oven is different than that of the burners. Rather than clicking, the oven ignitor will glow red. If when you turn of the oven you don't see a source of red light coming from under the oven bottom your ignitor is bed.
Aug 30, 2014 | Kitchen Ranges
Ingnitor glows bright yellow or red but oven doesn't light
Hello, welcome to FixYa.
Based on your description,I`d suggest it is the hot surface ignitor for the bake burner that is likely the problem...even though it glows, I'll explain further below.
Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined. It'll look like this...
** FIRST unplug the range and turn off the gas to the appliance before attempting any service...safety first**
NOTE: Some ranges have an upper broiler the same as the lower (bake) ignitor ( some do some don't ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
Here's a helpful link...
http://www.repairclinic.com/PartDetail/Hot-Surface-Glow-Bar-Igniter/316489400/1197384?modelNumber=790.71402700
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case. Many people overlook the ignitor, especially if it "glows" since that gives the untrained person the impression it works...that is not the case however. (Ignitor may glow but not have sufficient amperage to open valve, or open the valve slightly, even intermittently...but not hot enough to ignite the gas).
As far as checking them you don't actually need a clamp on (though it is the preferred method) you can also ohm it out to test it as follows...
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number based on the model number for the bake ignitor. The number I use in most applications (it's fairly universal and replaces both long and short ignitors and works in 90% of ranges out there)... is part #12400035.
I would still double check with your model number with the part`s professional`s if you're more comfortable with that.
Hope that help`s. Let me know if I can assist you further or if anything is not clear and good luck.
Thank`s for visiting "fixya" for your repair needs. Please take a moment to rate the assistance you received here and a brief testimony is also appreciated.
Regards,
Macmarkus :)
Oct 30, 2011 | Frigidaire FGF326AS Gas Kitchen Range
Ignitor glows but burner doen't ignite. Don't hear any gas flow or smell any gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 26, 2011 | Ovens
I have an Amana ARG7102W P1143347NW gas range that the oven will not light. All other functions work including the broiler and the oven ignitor glows brightly. I don't think it is getting gas to the...
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
Jun 12, 2011 | Amana Ovens
I have a King Pellet Stove 5510, I think the ignitor is out. It's going to be cold tonight and until I can get a new ignitor, can I start the pellets with something else.
If you have a hand held bottled type, propane torch, you could carefully try that. However, never ever use any type of liquid starter, like charcoal lighter fluid, kerosene, etc. All you want to do, is get a cup or so of pellets started burning hotly and let the auger take over feeding the fire from there.
Be extremely careful doing this.
Hope this helps you stay warm tonight.
Apr 16, 2011 | Heating & Cooling
Kenmore gas oven won't light. The pilot light is on but no gas. What do I do?
Put a torch on the probe. If the flame comes on them the thermocouple is weak.If nothing at all replace the safety valve.That is if you have a standing pilot. If you pilot is an electric one then it should be so bright it is hard to look at but if it is dim orange it is weak.
Sep 07, 2009 | Kenmore 30169 Electric Single Oven
My Charbroil grill igniter won't work. Have to
I';m sure everyone thinks they are giving good advice, but READ THE SYMPTOMS. The guy says his ignitor doesn't "click" anymore. And most of you tell him he needs a new gas regulator. Fix his problem, don't create new ones. He needs his ignitor fixed. Maybe just a new battery? Or maybe the whole ignitor unit But certainly not a new regulator, etc, etc.
Jun 29, 2009 | Char-Broil Grilling
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Dec 27, 2008 | Cooktops
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
