Question about RCA Televison & Video
Rca tv model number d61130 wont turn on
Wont turn on!?
4 Suggested Answers
SOURCE: MY RCA TVE WONT TURN ON
Did you change your battery from the remote?
Posted on Dec 02, 2007
Russmann
  • 203 Answers
SOURCE: rca model number d56w20
Most of the problems I've seen on that set are on deflection p.c.b. After removing rear cover it is the board on the bottom left hand side. Look in the middle section of it for 3 to 5 capacitors which are bulging on top. Replace them with higher value components. If they are not visable it is probably the high voltage transformer that needs to be changed. Either way it will require troubleshooting test equip. and soldering equip. You can replace the whole board with a rebuilt for around 250.00 Good luck, Russmann.
Posted on Jun 20, 2008
  • 185 Answers
SOURCE: RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Posted on Nov 11, 2008
How do I locate and change the projection lamp in my rca TV,model d61130,high depth TV?
I know this sounds crazy but please go to youtube and type in 'how to replace my lamp in a RCA rear projection TV' and you will get multiple video's showing how to do this.
Nov 09, 2014 | RCA D61W20 61" Rear Projection Television
Rca d61130 fuse location
One where power cord connects inside set (should be 6.3 amp) and another forward and to the left (rear view) on a narrow board.
Oct 29, 2012 | RCA D61130 TV
RCA D61130 rear projection tv will not come on. Power button blinks green as long as i hold it in.
Time for it to go to the shop---low chance a tech will fix it in the home
May 18, 2012 | RCA D61130 TV
RCA D61130 power light blinks green tv wont come on
Time for it to go to a shop--it is unlikely this brand/model will get fixed in the home.
Need part no. for cr14710 tv model no. D61130yx1
Part is marked as no longer available--you may be able to find it on the Internet-----------
RCA part number is 243846 (suggested list is $4.95)
If you cannot find it I would suggest you contact PTS electronics--they repair/rebuild all kinds of circuit boards and may be able to help you.
SD TECH
Oct 03, 2009 | RCA D61130 61" Rear Projection Television
60" rca tv has a double picture
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Apr 05, 2009 | RCA D61130 61" Rear Projection Television
RCA D61130 picture has a blue haze comes and goes?
The cooling fluid needs changed in the tubes and the algae wiped off the crt faces. This is not a do-it-yourself unless you're pretty darn good at fixing things.
Dec 28, 2008 | RCA D61130 TV
Moved now tv won't work
you can't fix it by yourself, unless you have basic training in dealing electronics circuits. I think the only problem with your tv set is loose connection, that needs a resoldering the circuit. But it take a lot of care to do it. I suggest to find somebody that has skills to do the job.
Jun 28, 2008 | RCA D61130 61" Rear Projection Television
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
