Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Ink cartridge alignment problem
Hi, I am having problem with my new ink cartridges.  I installed them and then went through the alignment process and printed test page.  The message that comes up in the window is "Print cartridge alignment failed."  There is a little exclamation (!) mark that blinks all the time.  Can you help me resolve my problem?  Thanks.  Dan
  • 6 more comments
  • Anonymous Nov 12, 2007
    I put in the cartridge and after it allignes and prints out the black page it shes "Printer cartridge alignment failed."
  • geordiearmy Nov 23, 2007
    Same thing...haven't found a solution yet !
  • Anonymous Dec 07, 2007
    yes
  • Shirleyf35 Dec 16, 2007
    I'm having the same prob. I've found the printer will print fine if you change the printer settings on your pc from general everyday printing to photo printing, but this is only a temporary solution, as when you switch the printer on again, you get the "please align cartridges" message.
  • dbhilltop Mar 25, 2008
    This error has shown every time the printer is turned on since the installation of a new black cartridge HP says I'm out of warrenty and offered to renew my warrenty & get tech support for 1 yr for $65. I can get a refurbished one for less than that .
  • fegan Jun 09, 2008
    Message comes up every time I go to print or copy that cartridge has to be aligned, and when it prints alignment, the message comes up that alignment failed. Please help me to resolve this problem.
  • datelsu Jun 25, 2008
    I have refilled (HP 4110 ) both Black & tri color cartrdge and have been using it for quite some time ,recently when black ink was irregular i took it out and found black cartridge was having enough ink(when shaken ink oozed out.) after i put it back as usual it asked for allignment page printing. printed page when placed for scanning; it repeatedly shows failure in alignment.
    and occassionaly & not always shows wrong cartridge inserted !
    please help.
    p.k.datta.
  • Anonymous Oct 20, 2008
    Same as first post. :(
Well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Posted on Aug 18, 2008
When i had the cartridge alignment failed garbage and needed to scan stuff, I turned printer off, then back on, and when it said alignment needed, I held setup and pressed OK, then it let me do it
Posted on Apr 28, 2010
I think this will work. At least it worked for me. I went through the printer SETUP button. Selected the TOOLS option, then pressed OK. First, I selected the CLEAN PRINT CARTRIDGES option. Wait until it finished. Second, I selected the ALIGN PRINT CARTRIDGES, under same TOOLS menu.
when the alignement process ended, it showed ot be succesful in the printer screen.
Hope it works for you all.
Posted on Feb 09, 2008
  • 3 Answers
After doing some testing (I'm having this problem myself), the problem appears to be with the black ink cartridge. Before I replaced my cartridges, I was using a 343 & a 348 (both tri-colours). Both were running low so I replaced the 343 for another 343, but put a 337 (black) in place of the 348. This is when I started getting problems with alignment. As a test, I took the 337 (black) out, put the old 348 (special tricolour) in again & tried aligning - it worked fine, so it would appear that the 337 black cartridge is the problem. Maybe HP have issued a duff batch, as it's an official HP product. I'm expecting another 337 any day now, so will try again with the new one & see if I get the same problems. But for those of you still having a problem, I'd suggest changing your black 337 cartridge. Sorry this is a bit long winded, but I thought I'd better explain in full! Hope that helps!
Posted on Dec 16, 2007
  • Shirleyf35 Feb 09, 2008
    yep - it appears to be a problem with the 337 (black) ink cartridge - i tried with another 337 & all is now fine so I suggest HP have issued a duff batch of cartridges.
I had this annoying problem and finally fixed it.
Steps I tried that did NOT work:
1. Align print cartridges (printer menu and computer settings menu)
2. Clean the cartridges (printer menu and computer settings menu)
3. Physically clean the cartridges myself using cotton swabs and water
4. Unplug the printer from the back of the printer while on to "reset" the printer
5. Tried switching from everyday printing to photo printing, but would not print since I still had the alignment error message.
The problem seems to be with the ink cartridge(s) themselves, not the printer per se. Both cartridges must be aligned properly for the printer to work. I use 93 tri-color ink and 98 black ink. Ultimately I found TWO of the new black ink cartridges I had purchased were defective and would not align, so I had to discard them even though I'd just purchased them. The third 98 black ink cartridge finally produced a successful alignment.
Thus, the solution as frustrating as it sounds is to keep buying more HP ink until you get both a tri-color and black cartridge - neither of which are defective - to work together.
Posted on Jun 15, 2010
Don't buy HP Poducts
Posted on Oct 26, 2008
I tried to clean & realign but it stills shows an error. HP is no help. I guess you need to align every time until you run out of ink & get a new cartridge. Why won't HP admit a problem & replace the cartridges?
Posted on Mar 25, 2008
  • marilyn_john Sep 13, 2011
    I've been plagued by the problem for months. The alignment always failed, sometimes could print anyway. Seemed to help to reinstall and bail out before installation was complete (it would start printing and then after completed installation, it failed). Today I visited hp.com and downloaded all the driver updates. Problem was solved.
    Scholar:
  • 121 Answers
Is this before or after you run the alignment.  Does the page print out?  Do you lay it on the glass and press scan?
Posted on Oct 26, 2007
SOURCE:
Press enter to alline cartridges
If you are getting Alignment failed or Align cartridge Error, It could be because of these possible reasons listed below.
1. Faulty Cartridge ( if you are replacing one now )2. Refilled Cartridge ( not filled properly )3. Cartridge Low on ink ( does not give printer enough ink to align the printer )4. Could also be Hardware Issue ( Most of the time the HP Printer has life time of 4-5 years )
First step,
Remove all the cartridges out and clean the electrical contacts ( golden Contacts ) with a lint free cloth and Re-install them again
It should go through the alignment process and complete it.
If it does not,
Try to access the Setup menu and under tools you will find Align Printer, Try this.
If the Cartridge ink is full or has adequate ink ( atleast 30% in each cartridge ), and the cartridge is not refilled, then the last option is to do a hard reset on the printer.
But Doing the reset your printer will loose network connection, all the printer settings and fax logs,
To do the Reset,
Disconnect the power cord from back of the printer ( while printer is powered on )While holding the # and 6 button at the same time, Connect the power cord back.Go through the setup process to re-setup the printer settings,If it still does not align the printer, You may give a try to install using new cartridge ( but i doubt, it could be the end of the printer.)
Call HP and check if they have any good offer or they can help you with aligning the printer once.
Regards,Suhail
Nov 13, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
I just changed all the cartridges in my epson stylus sx12 but still says theyre empty
p { margin-bottom: 0.21cm; }
According to your problem first make sure that you have installed the cartridges properly. Go the the printer properties in control panel and follow the steps open the printinging preferences tab> maintainance tab > Ink cartridge replacement> then the window will show the process of the replacement of ink cartridge. Follow those steps of replacement. Then let the cartridge be processed, it will take a few time. And then your cartridge replacement will be finished. Then align the cartridges from the alignment option in printing preferences as well. If it doesn't solve your problem then the cartridges are faulty, replace a new set of cartridge is recomended.
Jun 09, 2011 | Epson Stylus C88 InkJet Photo Printer
I just loaded new HP 94 and HP 97 ink cartridges in my HP 6210 Officejet. I went through the alignment process and received a sheet that had colors, but no black ink. The printout indicated the alignment...
Make sure all the protective tape on the Black cartridge has been removed. Also are the inks re-filled? I have seen many re-filled cartridges fail in a similar maner.
Nov 22, 2010 | Computers & Internet
Will not print alignment page. all 3 light on front panel begin blinking
hi, there is the Solution
IF YOU WANT TO SKIP THE ALIGNMENT PAGE, Press and hold the Setup button, and then press OK . the printer not prind very very well, but the product works.There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • The paper has already been printed on or is colored paper.
  • The ink cartridge is defective.
    THE COMPLETE ARTICLE IS HERE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=311255〈=en
Apr 07, 2010 | HP Officejet 5510 All-In-One Thermal...
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
Hello.
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
Dec 01, 2009 | HP PSC 950 All-In-One InkJet Printer
Unable to print color pictures.
Double check the number on your old ink cartridge and verify they match the new one. Double check that the sticker protecting the ink cartridge is off, and then try again. If all this is corrct at least take cartridge out and place it back in, it could be a bad connection. Hope this helps
May 09, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
10,883 people viewed this question
Clive
Clive
Thomas F. Schneider
