Question about Summer Infant Metal & Wood Tall Walk-thru Baby Pet Gate
Summer baby gate spring does not retract
When letting gate go it is to return to closed by a spring. does not do this any more.
  • Thomas Gebhart
    Thomas Gebhart Feb 09, 2014
    I found my problem the spring sheared off causing door not to return. Found the front cover comes off very easy with small flat head screw driver. Remove this cover under it there is 4 philips screws, remove these. Cover comes off and there should be two springs one facing each way. I removed broken one and flipped other spring over and reassembled. Door is returning has designed. (note spring was very sharp)
2 Suggested Answers
SOURCE: How do I install a Summer Infant pressurized baby
No camera
Posted on Mar 19, 2011
Dust non-return gate staying open, allowing spillage
Contact dyson support. http://www.dyson.com/support.aspx
May 11, 2016 | Dyson DC44 Animal Cordless Vacuum
How spring gate closer works without any human intervention or electricity?
It's a device that consists of high quality steel spring in a spiral shape which is installed around the door or gate that close the door automatically without any human intervention or electricity. For any further information about gate closers you can check this Web Site.http://www.gateshut.net/details-of-gate-closer.html
Jul 18, 2013 | Lockey Hydraulic Gate Closer TB600 Heavy...
What is Spring Gate Closer and How it Close the door automatically?
It consist of hard steel or aluminum in spring shape, which force the gate to shut it close the door automatically without any electricity or heavy internal mechanism.http://www.gateshut.net/
Jun 07, 2013 | Rixson Exterior Gate Closer With Sliding...
Is Spring Gate Closer use any internal mechanism or hydraulic system to close the door?
I think spring gate closer close the door on it's own. It's consist of high grade steel spring, which close the door automatically without any heavy internal mechanism,hydraulic or electricity.http://www.gateshut.net/
May 29, 2013 | Cars & Trucks
Ice maker will only dispence cubes, no crushed
I had this problem on a differnt fridge. What I discovered is that the tray has a spring that pushes the ice grinder into a postition by default. When you remove the ice tray, depending on whether the maker was set for crush or cube, the spring arm may reset to the undesired position. To fix it, I set the control on the fridge to match what was always coming out. Then I pulled out the ice drawer. Then I reinserted it and it lined up better with the interior controls. I ran some ice through it. Then after the ice matched the setting, I tried the other setting (cube or crushed). It was fixed..Hope this helps.
Aug 22, 2012 | Frigidaire Refrigerators
Door fell off and i have a spring
Hi
We would recommend returning the product to your retailer with your proof of purchase to discuss exchange or refund.
Apr 17, 2012 | Munchkin Protect Auto Close Gate
Rear door does not close
Look at the door's locking mechanism. Is the Latch Gate in the down position? Is the Door Mechanism properly tightened to the door? These are Torx/Hex head bolts. Tighten these if needed.
If the Latch Gate is down:
1. Unlock the door.
2. Lift up/out on the Door Handle as if you were opening the door.
3. Use a screwdriver to lift the Latch Gate so it lifts the Gate up and out of the way.
Alot of these Gates have plastic coverings that sometimes split and stick or cause the door mechanism to jam. Inspect the Door Mechanism for anything that could be causing it to jam. Using a pair of needle nose pliers remove any of this split plastic (if so equipped) pulling as much of it off the Latch Gate.
Use WD40 with the red spraying hose on and stick it as many openings you can and lubricate as much of the Door Mechanism as you can.
Check the operations (plural) of the Door Mechanism, Opening and Closing the Gate using the screw driver to push in the Striker Gate causing the Latch Gate to rotate back down into position. Repeat... checking for the Latch Gate to Release Up (on it's own) when you "open" the door. If it doesn't, then there is either jammed or a return spring is broken.
Have you dented or distorted the Door and / or Door Mechanism in the process of trying to slam the door close? You will have to either bend the the door area back to as close to possible the original shape. Use the other door on the other sides as a guide on this. You may have to replace the Door Mechanism itself, as when they are malfunctioning and are slammed (over and over) it could break the Mechanism itself. If the Mechanism is broke, you will have to remove and replace the entire mechanism.
Let me know if this helped, or if you have additional information of questions. Feel free to conatct me at FixYa.com!
Jan 17, 2010 | 2005 Saturn Relay
1991 ford festiva driver seatbelt will not retract
Common with Festiva and others as they get used - The retract spring is worn - Please have a new one installed cause later it may not pull out correctly - It's a safety issue -
Oct 16, 2009 | 1991 Ford Festiva
2004 Mercury Monterey tail gate handle came completely off. The left side's guide is in place, but the right side is retracted - hence can't just put it back in. Any ideas?
Open tail gate. Use the access square inside - pull cable to open tail gate. Remove interier panel - 2 bolts plus 2 screws (2 bolts on handle and 1 screw each side), pull remainder out of guide clips. Now have full access to locking mechanism. Identified a retaining spring had come loose sending guides to shift left (exterior point of view). Place hand in tail gate and move guides over and put spring in place to retain. verify it works and put back together. Handle is the trickiest part as the bolts have to go through the interior panel and afix to the metal tail gate.
Sep 20, 2009 | 2004 Ford Freestar
Summer Infant Metal & Wood Tall Walk-thru Baby Pet Gate Logo
110 people viewed this question
Top Summer Infant Baby Gear Experts
Colin Stickland
Colin Stickland
Paul Bade
Falling star
Are you a Summer Infant Baby Gear Expert? Answer questions, earn points and help others
