How to fix the top transmission seal on washing machine?
Oil is leaking in washing machine and I am getting oil spots all over clothes
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
You surely need a senior technician
Posted on Feb 10, 2014
4 Suggested Answers
Washer_tech
  • 164 Answers
SOURCE: oil in
your transmission is leaking or you have bearing/seal problems
Posted on Nov 11, 2007
  • 1028 Answers
SOURCE: Oil leaked into the washing machine tub.
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Posted on Jun 17, 2008
tzweeb
  • 318 Answers
SOURCE: whirlpool calypso washer black streaks
to all that are having a problem with these calypso washers... if you have paid for a repair then you need to check out the lawsuit... calypsosettlement.com and see if it applies to you.
but if you are getting a mark or a residue on your clothes, then look at the inner wash plate gasket, where it meets with the outer stainless steel tub. if there is a gap between the gasket and the tub then thats where the marks are coming from.
it happens alot and thats not covered by the settlement, but its not too bad to replace the inner wash plate. you need to remove the cabinet, then the tub cover and the innerwash plate dome. then 6 screws and the cover will come off.
replacing the inner wash plate will solve the stains and get you a few more years of use until you have to buy a new washer as more items may fail.
Posted on Jan 06, 2009
Oil leaking in washing machine
its a common problem and if your clothes are getting oil spots on them its a term known as "wash-back",the cause is the top transmission seal is bad and letting its oil out and into the wash water,it needs replacing,very labor intensive as you need to remove both inner and outer tube and remove transmission top to replace it,its cheaper to replace the whole ****** or the machine depending on how old and its use and shape
Apr 29, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
I am finding oil under my washer.
your transmissions lower oil seal is leaking and needs to be replaced,if the top seal goes,you will start to see oil droplets on your clothes when washed and this is called "wash-back"
Jan 01, 2011 | GE WBSR3140DW Top Load Washer
Black oil spots on white clothes after washing
your top transmission seal is leaking oil out of the transmission,and its getting forced up thru the tub seal this condition is called "back-wash" you need to remove the tubs both inner and outer to access the seal,it takes time
Mar 21, 2010 | Hotpoint VBXR1090D Top Load Washer
Oily spots on clothes after washing, no oil or grease before washing, no hard water...where are the spots comming from. Did not happen with old washing machine
sounds like the seal at the base of the tub is allowing oil to leak from the bearing (that is allowing the tub to spin on the motor shaft.
Not much to do unless you are good with tools and can remove the tub and replace the seal. (This is sorta like the seal between the transmission and engine on a car, or around the main motor bearing)
Feb 03, 2010 | LG WM0642H
Leaking grease
All washer machines have a "transmission" - just like a car these units have oil in them and when the seals that protect the oil from going to our clothes is breake, oil finds its way to your clothes.
Transmission needs to be replaced.
Aug 18, 2009 | GE Profile WPRE6100G Top Load Washer
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Spots on my clothes after washing.
the transmission seal may be going out leaking oil
Apr 24, 2009 | Kenmore Washing Machines
WASH MACHINE IS LEAKING GEAR OIL ON FLOOR AND WON'T SPIN THE CLOTHES OUT
If there is oil leaking out, you may have a leaking gearbox.
There is nothing you can do about that but replace the gearbox.
Here is a website link for parts.
http://www.theappliancepartswarehouse.com/seo_indexing.html?m=Whirlpool&s=18500
you can copy and paste this in your web search window
Feb 07, 2008 | Whirlpool LSN1000LW Top Load Washer
Oil in
Nov 11, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
