Question about Brother Sewing Machines
Brother cs-80 winding bobbin makes whirring noise and doesn't wind
Trying to wind my bobbin and it make a whirring noise but doesn't move. No error message and needle is stationary.
    New Friend:
  • 26 Answers
Replacing the bobbin winder rubber ring.
  • The case halves are held together by 5 larger screws, one under the carry handle, obvious from the holes in the casing, plus one smaller screw up by the foot-raising lever.
  • There is also the final screw, which is a devil to find. (see 3rd image)You have to remove the plastic tray to which the spool carrier is attached, up by the spool winder. You do not need to remover the spool winder stop but the small screw on the left, in the bottom of the tray-shape.
Next, WITH CARE , lever round the tray with a thin blade and use a small screwdriver to ease it out of the case; there are 2 bits that stick out more than the rest.
  • Once this tray is out you can see a small bar with a screw. (see 2nd image)Remove this screw and the 2 halves of the case will separate.
TAKE CARE NOT TO DROP THE SCREW INTO THE WORKS!. A piece of sticky-tack on the end of the screwdriver helps here if the screwdriver is not magnetized.
  • Now you can carefully ease the ribbon-strip cable from the circuit board and move the case round to be able to access the screws that hold the circuit board. You do not need to pull out the other cables; just take a tad of care as you work.
The bobbin winder mechanism is held in by 1 screw - take this out and you can then easily replace the rubber drive ring -(which you have providently ordered)
  • Take the opportunity to clear out any fluff and dust while you have the cases apart. Put ONE drop of oil in the center of the bobbin carrier rotating mechanism and one drop on any moving joints.
  • Replace the components/ ribbon cable in the reverse order, taking care not to drop the small screw! It is necessary to carefully line-up the hole into which it fits. It is surprising how easily the tray clips back into place, compared with the hassle you had getting it out.
I took both my CS 8080 apart last week to replace the drive rubber. It took nearly 1.5 hours along with the cleaning and lubing.
I am sorry the 3rd image is so small. It shows the screw to remove to access the arrowed screw in the second image
brother cs-80 winding bobbin makes whirring noise  - brother-cs-80-winding-bobbin-makes-qa0ugypaytbcwitrzme1v3l4-3-0.jpg
Posted on Feb 17, 2015
    Scholar:
    New Friend:
  • 47 Answers
The bobbin winder ring, (the rubber ring which drives the bobbin winder within the machine) on many of the lower end brother sewing machines have a tendency to melt/liquify. It's a very strange condition but is very common. If this has happened, it would be best to take your machine to a sewing machine repair shop to have the former bobbin winder ring cleaned out and replaced. If this is not the case, it is likely that your ring has become worn and is no longer making contact with the drive wheel, and should be replaced. I would not recommend taking this specific model apart to replace the ring yourself. It is not terribly difficult to take apart, but it can be very difficult to put it all back together properly, and this machine is particularly fragile, and could easily be damaged if you don't have a fair amount of experience with sewing machine repair.
Posted on May 15, 2014
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
SOURCE: Can't wind the bobbin
Hi again,
Well we finally downloaded a service manual that cost a few bucks, then finished getting the machine apart, then found a small rubber O-ring that had obviously gotten hot when spinning after the tangling of the thread on the bobbin stem. You could see where the heat had melted tiny teeth marks in the ring and it was stretched out of shape. It and yours too will need to be replaced.
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Posted on Nov 10, 2008
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
louislevel_2
  • 374 Answers
SOURCE: my needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Posted on Apr 07, 2009
Bobbin will not lock on bobbin spindle, what can I do?
Posted on Oct 19, 2011
Bobbin will not wind
For ~$25 you can purchase a stand-alone bobbin winder from the local fabric store (JoAnn's, Hancocks) or the internet, ie Amazon.com.
Nov 15, 2015 | Brother CS-100-T Computerized Sewing...
My Brother CS-8060/CS-80 is making a high pitched squeaking noise when I try to thread a bobbin. My manual has nothing about that kind of problem. I think it might be something to do with the belt or maybe...
Hi! The first thing I'd do is look for thread caught on the bobbin winding spindle, but below the little platform where the bobbin sits. It's really hard to get at, but if you shine a light from the side, you should be able to bend your head (or tilt the machine back) so that you can see the underside of that platform. When I've gotten thread caught on that spindle, I take my scaple or a craft knife and carefully cut the thread free, then use a set of tweezers to pull it out. You're working in a very cramped area, so be patient and go slowly.
Make sure the lid that uncovers the bobbin winding mechanism is as far back as it will go; the same goes for the spool that holds the thread.
Sometimes I get a a high-pitched squeaking noise (but it's not loud) just sewing. It comes from the handwheel and I don't know why my machine does it. It stops if I push the handwheel in (although the handwheel doesn't seem to be out.)
See if these suggestions help--if not, let me know, and we can try something else.
Happy Sewing!
Feb 05, 2010 | Brother CS-8060 Computerized Sewing...
Bobbin won't wind.
If this is new, ask at the shop where you bought it if they can show you.
As Janome dealers, we give several free lessons to familiarise customers with their new machines, it is good relations and keeps customers happy....your Brother dealer ought to be pleased to help, ....heavens, you may even want to go and buy some thread, or tell a friend how helpful they were afterwards !!
Go on....ring them and ask !!
Aug 27, 2009 | Sewing Machines
Brother CS-80 Sewing Machine Bobbin Rewind
For $30 you can buy a standalone bobbin winder (Sidewinder) at JoAnn's Fabrics or Amazon. It's a great little accessory (battery or electrical) because it saves wear and tear on your machine but also allows you to wind multiple bobbins without having to unthread the machine.
Nov 09, 2017 | Brother CS-80
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Hi again,
Jul 12, 2008 | Brother CS-8150 Computerized Sewing...
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Can't get Bobbin to wind properly
Verify that your thread path is correct when winding the bobbin. It has a distinctive path including a tensioner that helps your thread wind smoothly. Do not use a bobbin that is not wound smoothly because (as you already know) it could possibly break needles and damage the machine.
Brother CS 80 Sewing Machine Bobbin Rewind
Nov 09, 2017 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
145 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
