Question about LG LSC27931S Side by Side Refrigerator
Water dripping out from the rear of the refrigerator
Water is dripping out on the floor from the rear side of the fridge-constantly
  • 28 Answers
SOURCE: Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
Posted on May 09, 2009
  • 401 Answers
SOURCE: LG LSC27931S Side by Side Refrigerator? water
SOUNDS LIKE YOU HAVE AIR IN THE LINE, DISPENCE A GALLON OF WATER TO SEE IF THIS CURES IT. I HAVE SEEN PROBLEMS WITH THE COUPLER ON THE WATER LINE ON TOP OF THE DOOR.YOU MAY NEED TO REPLACE IT
Posted on Jan 12, 2010
SOURCE: defrost water is not draining into the evapataror pan
water not draining in pan in freezer
Posted on Sep 05, 2010
  • 552 Answers
SOURCE: Hi,I have a side by
this is a common repair on this unit, the defrost drain line is clogged and needs to be cleaned, let me know,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
SOURCE: I replaced my water filter
Just bought an off the floor LG fridge model number LSC27914SB and when I turn it on it beeps. Why is it doing that?
Posted on May 27, 2011
Why is the water dispenser constantly dripping?
If the water is coming from the water dispenser itself then most likely you have a water valve that bis going bad and it will only get worse.
Jul 13, 2015 | GE Refrigerators
Water seems to be gathering and then dripping from under the control panel which is situated in the main fridge, on the back wall, behind the top shelf.
sounds like a bad plugged evaporator drain plug? which then freezes up and moister - water/ ice build up takes place in fridge
Mar 08, 2015 | Refrigerators
Water appears on the floor outside the fridge. I have a side by side fridge freezer, Magic Chef
There's a tray under the refrigerator that catches the water dripping down when your auto-defrost cycle runs. Usually this water evaporates before the tray overfills. Either you don't have enough air flow around the refrigerator for the water to evaporate, or the tray may have developed a leak.
Oct 10, 2014 | Refrigerators
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Water dripping to bottom of freezer goes out on floor when you open door
Possible that it is the water that is overflowing from the defrsot drain tank from the bottom of the fridge on the rear.
You must move the fridge forward to take a look and to confirm if this is also from the tubing leak or from the evaporatorr tray.
If there is water connection the check the line.
Sep 22, 2010 | Frigidaire FRS26R4A Side by Side...
Water in carpartment under fridge.
thats the dispensor tank, is there a drip pan under neath the refrigerator?
Apr 24, 2010 | GE GSH25JFR Side by Side Refrigerator
Maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Jul 16, 2009 | Maytag MSD2756GES Side by Side...
GE Profile Side By Side leaking water on to floor
there must be a hole in the lower back of the freezer compartment that carries the water to the drip pan when the fridge goes through the defrost cycle. Water on the floor means that hole is plugged and the water seeps through the doors. See the owner's manual - it will describe this issue. The fix is to have the blockage removed by squirting a solution of hot water and baking sode with a turkey baster or a similar injector.
Mar 13, 2009 | GE Profile PSI23NCR Side by Side...
Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 25, 2008 | Frigidaire GLRT212ID Top Freezer...
LG LSC27931S Side by Side Refrigerator Logo
18 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
