Question about Garden
Ruixing carburetor model number location Model # PEA 438 . Carb kit A201152
Trying to find a Carburetor kit or replacement Carburetor
  • 86 Answers
SOURCE: Need new carburetor
I will check to see if I can get you one at a resonable price.
Posted on May 13, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 148 Answers
SOURCE: need brand/model no for my troy bilt 475SS carburetor
Have you looked on the Carb itself? If you look closely you should see a name and some type of marking of the model number.
Also look up the model number of your blower at www.managemyhome.com and you should be able to the owners manual from there (which should have it).
Posted on Aug 04, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: What carburetor fits ryobi 410r tiller?
http://www.oscar-wilson.com/MANUALS/BOLENS/21B-121R765.PDF there ya go..
Posted on Jan 29, 2010
Carburetor for a farmall 300 tractor.Just rebuilt carburetor and it floods...
How did You set the float? Did you replace the needle valve? What about the seat? What kit did you use and we need to model number off the carb.
Nov 28, 2016 | Farmall Garden
How do you adjust a ruixing carburetor on a pocket bike
Hi, Chad for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
RUIXING Carb trouble HP
carb tuning tips for more speed
How to tune adjust cateye pocket bike carb
pocketbike carb settings
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 01, 2016 | Motorcycles
Murray lawn mower model number m20300 trying to locate carberator
Murray M20300 is produce by Husqvarna (HOP) group. Its product number should be 96114002702. It uses a Briggs and Stratton engine model number 9T602-5019-B1.
The carburetor PN is 795475 which include the 795083 diaphragm and gasket. This diaphragm and gasket is most problem found when the carburetor fails to operate. Considering the cost of the carburetor kit it is just cost effective to purchase the whole carburetor replacement kit.
You can purchase from online vendors that sells Briggs and Stratton parts or purchase local from a local shop that deals with Briggs and Stratton engines.
Mar 26, 2015 | Murray Garden
Ruixing carburetor exploded view
hello, if you could give me model of your carb, I would be glad to assist you. Thank you
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Jan 12, 2014 | Garden
The motor on my MAch 522 snowblower will not stay running unless you keep pushing on the primmer for the carb
Main jet in carburetor is gummed up from sitting with fuel in it for an extended period of time. Remove carburetor, completely disassemble and soak it in a good dip style carburetor cleaner for a few hours. Then reassemble with new parts from a carburetor tune up kit. If it has a Tecumseh engine on it, the carb kit should be #31820. But just to be sure, get the model and type numbers off of it and check with your local small engine repair shop.
Sep 22, 2012 | Garden
I have a 25cc weedeater 358791030.I need a gasket repair kit for inside of carb. Sears told me they do not have repair kits for inside of carb only a gasket for carb mount.Any suggestions........Thank you.
Look on the body of your carburetor. There should be a set or two of numbers molded into it. Take these #s (they're the model # of your carburetor) and enter them into the Cross-Reference Page on PartsBuggy.com's website. If there is a kit available for the carburetor, you'll find it there.
Jul 12, 2011 | Craftsman 25cc Gas Line Trimmer
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
Weedeater enign will not start.I you put gas in carb it will start for a second in then it will kill.It is a ryobi ry30550
You probably have a fuel/carburetor problem. You will need to inspect the condition of the entire fuel system. Start at the fuel tank with the fuel filter in the tank.It should be fairly clean and still attatched to the end of the fuel line. Check for stray debris inside the tank. Then inspect the fuel line in the tank. Next, check the condition off all the outside fuel lines. They should be soft and not be brittle with cracks. Next up is the carburetor itself. There is a filter screen inside one of the 2 covers that can get clogged with dirt/debris. It is located under the cover that does not have the small vent hole. The diaghragms and gaskets on and in the carburetor need to be checked. They too should be soft and not brittle. Brittleness is caused by the gas evaporating and also the presence of ethanol in our gas now adds to this problem. Repair kits for the carburetor are available and are much less expensive than the price of a replacement carburetor. Many dealers online sell these kits, but you need to know the manufacturer and model number of your carburetor to get the correct repair kit. Ebay dealers have a lot of these carb kits available.
Nov 28, 2010 | Ryobi Garden
I need to rebuild the carburetor on a Stihl Model 025 chainsaw. An exploded view diagram would help.
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
May 19, 2010 | Garden
Garden Logo
391 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
