Oil droplets on clothes in washing machine
Washing clothers come out of the wash with oil spots and there is a ring of oil in the machine
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
It looks like bearing problem
Posted on Feb 09, 2014
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
fanny
  • 146 Answers
SOURCE: Dark Spots on clothes
There may be some pieces of mat stuck between the inner and outer drums. The quickest way to remove this is to remove the drain hose that leads from the drum to the pump and feel around the bottom of the outer drum and remove any foreign objects that may be stuck in there.
Posted on Oct 31, 2007
Washer_tech
  • 164 Answers
SOURCE: oil in
your transmission is leaking or you have bearing/seal problems
Posted on Nov 11, 2007
  • 217 Answers
SOURCE: small brown spots on whites
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Posted on Nov 29, 2008
  • 12 Answers
SOURCE: Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Posted on Dec 21, 2008
IWL16 mildew or black specks on clothers
could just need a good clean. these machines remove dirt from clothes very well, but it can build up on the inside of the outer. disconnect power, remove top (two screws under covers under lid), remove top bowl ring (8 clips) remove agitator (1 screw deep inside) remove inner bowl. scrub it. also trying a hot wash with some cleaning product to flush the machine every couple months can stop this happening in the future.
Nov 10, 2013 | Fisher Paykel EcoSmart GWL15
My washing machine is in a working condition but why the clothers are not properly wash and some kind of brown or black stain apeared. Even when white clothes are separetly washed. Is there any help can...
this could be Drum bearings gone if its oil in clothes, Is it very noisy during spin if so then Bearings, quite an expensive repair......Not always worthwhile...
May 03, 2011 | Candy Washing Machines
I am finding oil under my washer.
your transmissions lower oil seal is leaking and needs to be replaced,if the top seal goes,you will start to see oil droplets on your clothes when washed and this is called "wash-back"
Jan 01, 2011 | GE WBSR3140DW Top Load Washer
Oil spots on clothing from washing machine - GE top loader
faulty clutch seal, Not a DIY
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Washing Machines
Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
May 13, 2009 | Washing Machines
Spots on my clothes after washing.
the transmission seal may be going out leaking oil
Apr 24, 2009 | Kenmore Washing Machines
Dec 20, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
