Question about Necchi Sewing Machines
The bobbin thread will not come up
I have tried the following to resolve the problem: rethreaded the machine upper thread and the bobbin case, removed the bobbin and case, as well as the shuttle race which I cleaned, oiled and replaced. I changed the needle and the bobbin and still the bobbin thread is not being "pushed up" where the upper thread can bring it up. I'm out of ideas and would appreciate your assistance. Tkyou, Karen.
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 152 Answers
Lower your needle
Posted on Aug 05, 2017
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
Posted on Sep 19, 2008
  • 15 Answers
SOURCE: Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Posted on Sep 06, 2009
  • 2702 Answers
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
  • 20 Answers
SOURCE: bottom thread too loose; tried
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Posted on Dec 18, 2010
  • 1788 Answers
SOURCE: Needle won't pick up bobbin thread. Has been
Most of the time it is because the needle was inserted with the flat side facing you instead of away from you. And for the heck of it, put in a different needle, there may have been a burr or some defect on your new needle. Other than that, it could be your timing.
Posted on Apr 04, 2011
The lower thread on the machine is jumpy, creates a loose (loopy) stitch every 1.5 cms or so. The upper thread is taut, but makes no difference if I put tension dial on lowest setting.
Hm, if the bobbin thread stitch is inconsistent, I would guess it is a problem with the bobbin tension. You might try picking up a new bobbin case for our machine. Bobbin cases do wear out or get damaged or there may even be a burr somewhere that is catching the bobbin thread.
Something else to try, before buying a new bobbin case, is:
Avoid old or bargain bin threads!
Install a brand new needle (compatible with the fabric & thread).
Remove the top thread from the machine.
Try a different brand of thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the upper tension to the midway point and test your machine.
Adjust the upper tension until the bobbin and top threads meet in the middle of the fabric.
Jan 19, 2018 | Sewing Machines
Bernina activa 130 tension loose after needle breaking into bobbin area
Is it the bobbin tension that is very loose? Try tightening it. Also check that the bobbin has been installed in the bobbin case, turning the correct direction and that the bobbin tension is threaded properly.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
If it is the upper tension that is loose and creating "thread nests" under the fabric, the machine is either misthreaded or possibly the thread is not seated completely in the tension disk.
Remove the upper thread from the machine.
ALWAYS RAISE the presser foot and rethread the upper thread from the beginning--verify the thread path is correct.
Set the upper tension to the midway point between high & low number (the factory standard--although it may need tweaking later for your particular machine).
Retest your machine. Hopefully, the issue has been resolved. If not, it may need service.
Tutorials Urban Threads Unique and Awesome Embroidery Designs
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Oct 03, 2016 | Bernina Activa 130
My husqvarna 870 fix but stays on causing the machine not stitching
What you have is commonly called "bird nesting" or "thread nesting" and is usually caused by the upper thread. Most times the thread is not seated in the tension disk, the machine is not threaded correctly (sometimes the thread will jump out of the take-up lever or a thread guide), or the upper tension is too loose.
1. Install a brand new needle.
2. Remove the thread from the machine.
3. ALWAYS RAISE the presser foot and rethread from the beginning. Verify that the thread path is correct.
4. Load the bobbin in the bobbin case (make sure it is spinning the correct direction), thread the bobbin case, and install it in the machine.
5. Set the upper tension to the midway point.
6. Test your machine. You may need to tweak the tension a bit, but tension is not static and should always be tested and adjusted for the fabric, needle & tension of every project. The tension is correct when the upper and bobbin threads meet in the middle of the fabric.
If it continues to be a problem, you may consider taking it for service.
Jun 07, 2016 | Husqvarna Sewing Machines
The needle with top thread couldn't draw the bottom thread from the bobbin to ready the machine for sewing
Are you saying that the upper thread is not pulling the bobbin thread up to the top?
Remove the thread. RAISE the presser foot and rethread from the beginning--allows the thread to seat completely in the upper tension disk.
Check that the bobbin thread is inserted in the bobbin case facing the correct direction and that the bobbin case is threaded correctly through the bobbin case tension. Be sure to leave at least a 6" tail of thread on both the upper and lower threads.
If it is still not picking up the bobbin thread, the bobbin case may be defective/malfunctioning or your machine probably needs professional service.
Feb 27, 2016 | Sewing Machines
Bobbin threat loose
Make sure you have threaded the machine properly--which usually involves removing the thread and rethread from the beginning. Make sure to RAISE the presser foot before threading the upper thread. Check that the bobbin is loaded in the bobbin case and it is threaded properly.
sewing machine loose bobbin thread Google Search
Jan 26, 2016 | Sewing Machines
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
My Kenmore sewing maching 385-19233 has problems with the tension. the lower thread is coming out with tiny loops - almost like a double thread. I am not able to correct it by adjusting the tension dial,...
Usually, it is the top thread causing the problem. Rethread entire machine. Then, pull both threads (upper and lower) with the presser foot up and leave a 6" tail. Make sure that you do not miss any guides, check your manual to make sure that you haven't missed a guide in your threading, and the direction of your thread on both bobbin and upper going the right way Youtube has excellent videos on threading for free..
Dec 14, 2017 | Kenmore Drop-In Bobbin 505S-21BH...
The bobbin thread is not catching. I have rethreaded the entire machine multiple times, tried different bobbins, etc. However, the needle and thread are not catching the bobbin thread. The bobbin thread is...
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Aug 01, 2010 | Brother Disney PE-180D Computerized Sewing...
Sep 05, 2009 | Sewing Machines
Sewing Machines Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
