Question about DeLonghi Microwave Ovens
The mica inside my delonghi microwave has a burnt hole in it and its sparking and arching in centre
Falling Down
  • 67 Answers
SOURCE: Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Posted on Nov 30, 2007
Richie_asg1
  • 1036 Answers
SOURCE: sparking inside. Little mica cover
Hi there.
Unfortunately this is how most microwaves die. The Magnatron that generates the microwaves (behind the cover) overheats and charrs the insulation between the high voltage contacts.
You would be best to obtain a new unit or have it repaired,
Spares are usually available, but sometimes it is not economically feasable.
Hope this helps.
Posted on Jun 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: arching microwave oven
The area that has arced needs to be cleaned thoroughly, and if the paint is affected, it will need to be sanded smooth and cleaned with alcohol.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If the rack support is charred or melted, it will need to be replaced. It's best to replace them as a set.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
  • 958 Answers
SOURCE: arching inside microwave
un plug it right away.
there are carbon deposit near the wave cover. the arching is coming from the magnetron to any exposed metal inside the unit or any carbon deposit since carbon is already conductive, it is sensing it as a metal.
remove and clean the interior of the microwave. polished and paint all exposed metal that you will find in the interior.
then test again the unit.
tnx 4 using fixya,
drcool
Posted on Sep 30, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: we have a ge microwave. Sparks came out of
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the mica waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
Sometimes it is the ceiling of the oven.
Your owner's manual may address this. You can download GE owner's manuals and installation instructions here.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.AC
Posted on Oct 11, 2009
Massive sparking and noisy when switched on to heat
There are 2 things that cause the massive sparking:
1. you placed inside the microwave oven a metal plate or one with silvery or golden drawings;
2. the mica sheet that covers the magnetron window is compromised (has holes, it is cracked) or it is covered with burnt (carbonised) food.
You have to carefully inspect the mica sheet and wash or replace it, if necessary. Hope that helps.
Regards,
Dan
Oct 10, 2016 | Microwave Ovens
Hole burned in panel inside next to ligt
take it in for repairs or just replace it
Apr 26, 2015 | Sharp Microwave Ovens
Sharp carousel microwave
Sometimes, bits of food get behind the microwave generator mica cover and cause this EXACT problem they short out the microwave energy and spark. . It is NOT broken but DONT let this happen for more than a few seconds. !!!! You will see the Mica (looks like plastic) cover from inside the oven and will be on one of the sides.It looks oblong normally, It is actually transparent to Microwaves and is how they get from the generator in to the oven. Give it a real good clean around the edges or better still take it out to clean. and it should be fine
Aug 25, 2014 | Sharp Carousel R530EST Microwave Oven
I get an occasional spark when microwave is in use
Presuming that you have iliminated the possibility of any metal objects that are not meant to be in the machine being in there (and this includes dishes and other items with silver or gold leaf on them, which WILL spark and burn!) then take a look inside the oven its self. You will find a waveguide cover. It is usually a strange flakey silvery plastic/card like material called Mica and is usually on the same side of the microwave wall as the control panel (So if the picture on this thread is accurate, I will guess the Mica cover is on the right hand wall inside as you look at the machine from the front) . Over time, the magnatron (the thing that creates the microwave energy) will often burn a hole through the mika, or cause a dark brown or black burn mark in it. If this cover is even slightly damaged then it may well cause sparking inside the machine. These covers are designed to be removed and you can buy replacements for them from electrical stores.
Aug 12, 2011 | GE Advantium SCA1001HSS Convection...
I need a new door for Delonghi Combi micro/grill model no. DMX30
You should be able to find help at the DeLonghi customer service site.
Mar 04, 2009 | DeLonghi Microwave Ovens
Sparking roof of my miele M613G microwave
these ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Feb 23, 2009 | Miele M613GSS 800 Watts Convection /...
Mica -sparking and on fire
You can order spares here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | DeLonghi MW 535 Microwave Oven
Sparking inside. Little mica cover got a hole
Hi there.
Hope this helps.
Jun 14, 2008 | Whirlpool Microwave Ovens
Burnt ceiling
Well microwave probably was too close to the ceiling and it wasn't getting enough air through and it got hot then bam you have a hole in your ceiling... if your microwave is completely ruined then don't bother with it just get a new one but if it works try moving it farther away from the ceiling.. good luck =]]
Feb 03, 2008 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
