Question about Sole Fitness Sole E95 Elliptical Trainer
Sole e95 elliptical console flashing
I unplugged my elliptical from the power source and replugged it in. Since the green dots along the bottom of the console flash simultaneously every 60 seconds. Can this be fixed? I had the machine 5 years before this with no problems.
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
I need schematics for Manufacturer's Product Number: 022670
Step 1:
you must find it. in www. fitnessrepairparts.com
however see the diagram attached FOR troubleshooting and fix it.
God bless you
Step 2:
Step 3:
Jan 08, 2013 | RTO Sole Fitness Package F85 Treadmill &...
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Operating manual sole e35
go to www.iconservice.com for free download
or http://fitness.manualsonline.com
Good luck,sincerely. G-d bless you
ERNESTO CUADRA
MANAGUA,NICARAGUA
Dec 12, 2011 | RTO Sole Fitness Package F85 Treadmill &...
Blue light flashing along with a green intermitent flash
Very comon with sharp aquos,try unplug,replug tries the power button on off couple time.Tv should work,don't than ur video backlight main board it dead.
Nov 12, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power ramp does not work.
Ignore everything above - most of the time this is an easy fix. Usually, it happens with a brand new console, or a machine that has reset itself.
Hold down the incline up (on the console itself) button and the start button at the same time. Then follow the instructions on screen.
It will run through an initial calibration, and once complete, the ramp will now work. Just did this with mine, and my ramp is now working perfectly.
Mar 19, 2009 | Exercise & Fitness
Sole Fitness Sole E95 Elliptical Trainer Logo
62 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
