Question about Vitamix 5000 Work Top Blender
Variable speed does not work - Vitamix 5000 Work Top Blender
  • Vitamix Master
  • 1,631 Answers
Check here for replacement of necessary part to be replaced.
Fairly easy to do. You can find a video on how to replace a vitamix potentiometer or Pot for short, check youtube.
Posted on Mar 16, 2015
Blender appears to be stuck on high. Today we changed the variable speed button blender still appears to be stuck on high.
The speed control usually is by electronics. The speed control switch will merely be telling the circuitry what speed is required but if the circuitry is faulty nothing will happen.
May 13, 2016 | Vitamix 5200 VariableSpeed Blender
Why isn't variable speed variable?
If you replaced and wired up the switch and potentiometer correctly and the new parts are not faulty that only leaves the Printed Circuit Board as the cause of the problem, it won't be the motor.
Feb 25, 2016 | Vitamix 5200S Blender Package
Vitamix 5000 variable speed control broken
Have a look at this, this guy has done the job.
http://uppityairlinepilot.blogspot.co.nz/2012/09/vita-mix-5000-variable-speed-fix.html
May 18, 2015 | Vitamix 5000 Work Top Blender
Why does my vitamix machine only have low and high, no variable dial?
You need to pay more money and buy the better model to get the speed control.
Jul 06, 2014 | Vitamix 5000 Work Top Blender
On my Vitamix 5000 the variable speed control does not work
It will probably just need the pot replacing, take note of where the wires go. I see someone else here is doing the same job and wants to know where to put them back. Take a photo first saves a lot of grief. The pot is the rotary resistance switch behind the knob.
Mar 24, 2014 | Vitamix 5000 Work Top Blender
Need to replace speed control
They are called a "Potentiometer" or Pot for short.
Variable Speed Control Switch
check here:
Feb 19, 2014 | Vitamix Blenders
Can't unscrew drive socket on vitamix super 5000 to replace it. The 5/64 hex wrench does not fit in. And another problem is that variable speed does not function. It is possible only slow or high speed.
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop. Speed control problem will likely involve replacing the control switch assembly.
Aug 25, 2013 | Vitamix 5000 Work Top Blender
Vitamix variable speed not smooth
Some models had a weakness with the variable resistance in the rotary switch but your description sounds more like the main PCB or even the motor both of which are very expensive parts to replace.
Nov 04, 2017 | Vitamix Blenders
My vitamixer's variable speed switch is stuck on about 2/3 speed. the on/off switch works fine. the high/variable switch changes from high to about 2/3 speed. the variable speed dial has no effect of the...
This problem sounds like failure of the Variable Speed Potentiometer component. Here is the most helpful Fixya article so far: http://www.fixya.com/support/t6032529-need_replace_speed_control
I have the same problem right now and don't want to pay ridiculously high prices for a small electronic component.
So far, this is as far as I've gotten in researching replacement parts:Vitamix Part #015955
Partstown sells #15955 for $23.39 on their website but I found out they charge $15 for shipping -- for a one-ounce piece of electronics. I won't pay to be ripped off on shipping so I won't buy one from Partstown until I've exhausted less-expensive suppliers. Here is the product at Partstown: http://www.partstown.com/vita_mix/vm15955
Another Fixya contributor, Robert Sadler, said he was going to try a generic potentiometer from Mouser.com. His descriptions are kind of vague for me. I'm not an electronics expert so I'm not very confident I can interperet his description:
"If you are comfortable with soldering, you can get a replacement part at Mouser.com. The pot is a 5k "slimline" made by Bourns, however looking inside the cover it looks like most pots would fit. I ordered one for a bit over $5 and will update when I get it with how it worked. You would just have to solder the existing wires to it." -Robert Sadler
I have no problem soldering the existing wires onto a new component but I don't really know what would be an appropriate potentiometer to buy as a replacement from an electronics supplier. In addition, Mouser's website seems to sell potentiometers only in bulk quantities of 5, 6, 12, or 45 items at a time. I just want one.
If anyone knows how to interpret Robert Sadler's comments, or has actually done this repair, please post below. I'm sure quite a few people would benefit from a high-quality repair at a low component cost.
Apr 08, 2010 | Vitamix 5000 Work Top Blender
Vitamix 5000 Work Top Blender Logo
190 people viewed this question
Top Vitamix Blenders Experts
Holly...
Holly...
ray gallant
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
