Question about Sharp MX-M350 All-In-One Printer
Language panel english - Sharp MX-M350 All-In-One Printer
Change language to English
If you have Win7, download the English Language Pack first and then change language;
Control panel, Region and Language, select language.
Jan 28, 2014 | Computers & Internet
My computer had some loging in problems and when i took it to get fixed they changed the language from English to Spanish (where i live they speak spanish). I want it to go back to English but i cant...
You do the below seteps: This is what you do:
Start > Control Panel > Clock, Language, and Region > Regional and Language Options.
Once in the Regional and Language Options, click the Keyboards and Languages tab. If you see a drop down list of languages, see if it is set to English. If not, set to English. However, if you do not have this list there, you may need to install it.
May 21, 2011 | ASUS Eee 4G Notebook
I want to change my laptop to english language
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
May 14, 2011 | Toshiba Satellite P105-S6197 Laptop
How to change my computer window xp operating system language from chines to english
Hello yay.... Open the control panel and then click on "clock, language and region". Then click on "keyboards and languages", then click on "change keyboards"
Joe
Thanks for choosing Fiixya!
Dec 28, 2010 | ASUS Eee 4G Notebook
My new netbook is in French. How do we get it into English.
Well first of all you may Open Regional and Language Options in Control Panel, to open Regional and Language Options, click Start, click Control Panel, and then double-click Regional and Language Options after then you may select English Language. The Key Settings button is available only if you have added multiple languages or keyboard layouts.
Good Luck!!
Thanks for using FixYa!!
Dec 25, 2010 | MSI Wind U100-030US Laptop
I just purchased my HP 4500 printer and began to install it. I see an error (!) symbol and I believe German writing. I need to remove that symbol and change the language to English.
Selecting the display language
To change the display language on the printer control panel, do the
following:
1 Press and hold [SELECT] on the printer control panel while pressing
the standby button (power switch). Continue holding [SELECT] until
the control panel displays
SELECT LANGUAGE (in English), and then release the [SELECT] key.
2 When the control panel displays LANGUAGE=ENGLISH *, press
[VALUE] repeatedly until your language choice appears.
3 Press [SELECT] to save your language choice. An asterisk appears
next to the selected language. Then press [GO].
4 After the printer warms up, the control panel displays READY in the
selected language.
Note
If the control panel does not display the message in the language you
selected, press the printer standby button and repeat the instructions for
changing the display language.
Dec 07, 2010 | HP LaserJet 4500 Printer
How can i change the french language to english language because our laptop was a french language and i dont know how make it english
Go into Control Panel, select Region and Language, choose a display language by installing English first.
You may need your Windows Installation Disc!
Oct 17, 2010 | Acer Computers & Internet
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
Changing language
Hello
You cant change your language on your laptop true control panel, you need to reformat your laptop in the English language. the options in control panel is just for your regional settings and keyboard settings and so on.
only OS that you can change language in is the Vista Ultimate and then you need to install a language pack.
Oct 14, 2008 | Toshiba Satellite A100-S8111TD Notebook
Labymistake change languge
Hi, In Windows XP Pro: Start, Control Panel, Regional and Language, Tabs > Regional Options, Languages and Advanced. Vista should be that far off. Start, Control Panel, "Clock, Language, and Region", Regional and Language Options Tab > Keyboards and Languages, Display language, English, OK, Reboot Hope this be of some help. Good luck.
Aug 18, 2007 | IBM NetVista PC Desktop
Sharp MX-M350 All-In-One Printer Logo
15 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
