Question about Magellan RoadMate 700 GPS Receiver
No signal The satellite search shows up in the map picture, spinning around but the cursor never moves and does not give me directions. The view button gives me the directions step by step and the simulator works but for minute by minute directions the GPS does not work. Is there a problem with the antenna?
  • 1 more comment
  • jgrapps Nov 09, 2007
    Hey Guys, I am having the same problem the only difference is that if I leave it off and not connected to the power for a few days and then power it up it actually works for a few miles and then loses the signal and never finds it again....I followed your instructions to the letter...I Removed the Antenna while in the upright position, cleaned the connection and replaced the antenna. I set the GPS to the current position. Then initialized the GPS and I made sure I had a clean line of sight to the sky. Then turned the unit off and back on. I am still having the same issues...
  • Anonymous Nov 22, 2007
    When I turn mine on in the car it takes about 15 min. to find the satellite.Should I contact the company by phone? Roadmate 700 about 4 yrs old could be less.
  • Anonymous Nov 27, 2007
    no signal .
    New Friend:
  • 24 Answers
NOTE: If you are trying these steps from your vehicle, it is
Recommended to follow when the vehicle is in a stationary position.
Make sure that the device is exposed to the clear view of sky.
With the antenna pointing upwards, remove the antenna and then re-insert.
Swivel it up and down to make sure its securely placed.
wait for few mins and check the signal indicator.
Still not working,
  • Turn on the unit and select any user.
  • Make sure that the antenna is in the upright position and the unit has
    a direct line of sight with the sky.
  • Select 'Option' from the keypad.
  • Then select 'Configuration'.
  • Scroll down to select 'Diagnostics'.
  • Scroll down again to select 'Initialize GPS'.
  • At this point you would receive two options, 'Yes or No' - select 'YES'.
  • Now scroll down and select 'Set GPS Position'.
  • Enter your City, Street name and number at the corresponding
    prompts.
NOTE: The address that you are entering in the Set GPS Position should be the address at which you are at that point of time.
Posted on Jan 27, 2008
Remove the Antenna while in the upright position, clean connection and replace. Set the GPS current position. Then initialize the GPS. Select Yes and leave the unit alone for 20 minutes. Do not press anything else. The initialization runs in the background. make sure you have a clean line of sight to the sky. Then turn the unit off and back on. You should be OK.
Posted on Oct 28, 2007
Distance from Stockton tx to midland tx in miles
Rather than give you the answer, let me tell you how to find the answer (very easily) yourself.
Go to www.maps.google.com and then search for either one of the two cities you're looking for. Say for example you search for Stockton, TX.
Once you find Stockton (Fort Stockton), then zoom out the map until you have both cities displayed.
Now place your mouse cursor directly on top of Stockton then RIGHT-CLICK - a drop-down box will appear and one of the options available is "Measure Distance", so LEFT-CLICK on 'measure distance' and you will see that a small black circle has just been placed on Stockton. Now move your mouse cursor over to Midland and LEFT-CLICK on Midland.
Voila! you now see the distance (as the crow flies) displayed on your map. Wasn't that easy?
Aug 05, 2014 | Radio Communications
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
Can't acquire signal
You can't, there will always be times and places where the unit can't pickup satellites.
Have you tried hitting view map or set a destination, just checking.
If you have and it can't show it, it's because it can't pickup satellites where you are.
Apr 13, 2013 | GPS
My maxent plasma is a 58" and the picture jumps alot and more on some chanels if we play a dvd picture is ok
If you are using satellite or digital OTA (over the air) through an antenna, you might need to retune your TV, it sounds like the signal is not quite good enough to give a solid picture. If you rescan and nothing changes, either point the aerial/dish so it matches other neighbours directs or get someone in to do it professionally. I'd recommend a professional, as they can move the aerial if it needs moving (this can happen if others build tall buildings around you).
Thanks
Moza805.
Aug 30, 2011 | Maxent MX-42XP10 42 in. Plasma HDTV
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really...
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Jun 25, 2011 | Coship CDVB2000E
At first it was giving me a (time to update map msg) now it won't pick up a satellite signal at all
1st go to Setup and make sure you have all options the way you want it.
To lock in satellite connection, make sure your device has an unobstructed "view" to the skies... no trees, ceilings, etc. A dashboard window is OK. Give it time. Sometimes it is 5 minutes (while driving around), other times its 1 min. CHeck Setup that it is not Simulating GPS - Turn it OFF.
Dec 29, 2010 | Garmin n?vi 260W GPS
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
THX 2005 Lincoln Navigator System foes not
This is because the buildings are so high that they mask the satellite signals. I have the same problem in the city of Toronto. The secret is to use Google maps on your phone because that uses cellphone signal which has better coverage. The satellite system has to have a clear view of at least three satellites. This keeps changing as you go through intersections and the Nav system can't recover quick enough..
Dec 09, 2017 | M&K Sound Mp Series 750 MK II THX System
Do you have the instructions for dokapon?
Hi....here it is:
Gameplay Controls Printable View Dokapon Kingdom GAMEPLAY CONTROLS:
wii_dir.gif Control Pad Move. Move Cursor. Up = Magic (Battle). Left = Strike and Counter (Battle). Rock (Roshambo). Down = Skill (Battle). Give Up (Battle). Scissors (Roshambo). Right = Attack (Battle). Defend (Battle). Paper (Roshambo). wii_a.gif A Button View Shortcut. View Space. Open Help Menu. wii_b.gif B Button Bag Shortcut. Display the World Map. wii_1.gif 1 Button Cancel. Movement Shortcut. Data. Show Information. wii_2.gif 2 Button Make Selection. Confirm Message. Stop Spinner. Show Available Moves. Speed Up Cursor. Show Predications. wii_minus.gif - Button Flip Page. Switch Between Opponents. wii_plus.gif + Button Data Shortcut. Flip Page. Switch Between Opponents.
Aug 05, 2009 | AIA Dokapon for Game Boy Advance
I have a Tom Tom GPS and all of a sudden it says searching for satellite signal but never picks one up. Any suggestions?
To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays grey and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal…
  • The GPS signal was lost … sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after travelling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full colour and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Make sure battery is fully charged before use
Reset your device
Jul 24, 2009 | Tomtom XL 330 Car GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
101 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
