Question about Frigidaire FRS26KF5C Side by Side Refrigerator
Refrigerator has power supply, but nothing works
Refrigerator has power going thru it, but nothing works
  • Official Brand Answer
  • 4,342 Answers
Hi fred_n705, thank you for your post!
From what you have described, it sounds like you either have a communication problem with the control board, faulty temperature control, or sealed system issue. This is not a typical DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Best regards!
Posted on Feb 11, 2014
No water
If you are getting ice then you still have a water supply. If not then make sure the water is turned on behind the fridge. I would next check for power to the solenoid when the door switch is pushed. Then check to make sure there is power to the switch. My best guess it that you have a faulty door switch or the wire was accidentally loosened or taken off when the person was working on the ice.
Apr 14, 2014 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool refrigerator not turning on
Probably you have a bad power supply for the refrigerator or your condenser doesn't operate but wait a minute you said that you're not even receiving power so probably go with the power supply for the unit
Feb 06, 2018 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
In door water dispenser of ED25QF will not dispense water. New filter, cannot detect kink in supply line, pump does not sound, still making ice, light in door works, dispenses/crushes ice. What is the...
The pump motor on the dispensing water is the problem. Pump motor problem is cause by no voltage power to motor, burnt motor winding, switch faucet on dispensing water, water supply line has jam, check it if you can if not, call a refrigerator service technician to do the job.
I hope I help you with your problem. Thanks!
Jun 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Fridge and freezer suddenly stopped cooling - temperatures are rising rapidly - power is on lights and switches working
If the fans are working then the compressor may not be working . If nothing is on the defrost timer may be stuck in defrost.
Nov 22, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Thru the door component stop working...what parts need replaced? going to take? lights come one but nothing works...water or ice.
It sounds like one of two things 1. your water filter is clogged or frozen, if you still have the bypass try that. if it works after that you just need a new filter, around $40 or 2. your waterline is frooze, try pulling out the crisper drawers anf heating the line with a hair dryer
Good luck
Jun 07, 2010 | GE Caf? 25.4 Cu. Ft. Side-by-Side...
Usb ports on motherboard are not working. They do not seem to have any power. None of the ports work. Not even the front ones. I've tried reinstalling the drivers, installing different drivers, I've...
If the usb ports don't seam to have power, I suspect that at some time something was plugged into one of the ports, either at an angle or upside down, shorting the +5 vdc supply. Usually the supply voltage is fed to the ports thru a "zero ohm resistor", basically a fuse that blows protecting the power supply. You may be able to find and replace it but much easier is to install a 4 port usb pci card. They're cheap and you can go to 2.0.
Jan 13, 2010 | EliteGroup P4M800-M7 Motherboard
Refrigerator isnt cooling but freezer is working
It sounds like the fan that supplies air ciculation thru the freezer and refrigerator is wearing out, this problem is very hadr to detect because the fan does spin but not at the rpm's necessary to move the air thru the freezer and refrigerator. This repair/replace is a minimum of $300.00 parts and labor.
Jul 29, 2009 | Refrigerators
Flushing water hook up to Ice maker
I would go through 2 trays of ice to flush. Also if you have a door water dispenser go through 2 gallons that way to clean line.
Apr 12, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Admiral Refrigerator Ice Maker
pull your icemaker tube out and see if it is frozen with ice,let me know-mike
Sep 22, 2008 | Admiral Refrigerators
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
