Question about Altec Lansing Technologies Audio Players & Recorders
Altec lansing connect
Can I play music from my iPhone on an Altec Lansing IM600? If so, what type of cable do I need?
  • 1,511 Answers
IM600 Compatibility: iPod mini; iPod classic 3G, 4G, 5G, 5.5G, 6G; iPod nano 1G, 2G, 3G, 4G; iPod touch 1G, 2G; auxiliary input connects to any CD, DVD, or MP3 player using a stereo mini-plug. If you have a mini-plug port on the IPhone which I believe you have; then attach a male to male plug in between the two devices. Take to Radio Shack for correct line plug.
Posted on Feb 10, 2014
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
preachw996
  • 1179 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
It won't work like this due to this being a computer only speaker system. It requires the drivers to work with a computer & a Home theater does not recognize the format. Sorry.
Posted on Feb 25, 2009
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
Have Altec Lansing im600 and not charging iPhone 4. is there a firmware update?
Hi! Are u able to play anything from the speakers from ur iPhone 4? Mine charges, but won't play
Feb 13, 2011 | Altec Lansing Inmotion-IM600...
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
I have an im600 altec lansing. I've had it for at least a year. My iphone 3gs was being recognized and able to play its ipod through the docking station, but since I jailbroke it the iphone it hasn't...
I used a 2G jailbroken iPhone and it worked fine. Try looking elsewhere.
Example: my im600 was placed on a fridge (metal) that caused strange interference problems!!
Sep 03, 2010 | Altec Lansing Inmotion-IM600...
Where to find a speaker replacement for InMotion IM600
hi,i have 2 speakers salvage from im600 ozzyris7@hotmail.com
Mar 24, 2010 | Altec Lansing Inmotion-IM600...
I need to replace the Ion Battery for the Altec Lansing IM600
2 screws at the back removed with a cross head screwdriver. Remove the casing, then the battery plugs in to a white connector.
Jan 23, 2010 | Altec Lansing Inmotion-IM600...
Lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email address.princemonac0@yahoo.com and I will invoice you through paypal. Thanks
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
5th generation iPods hose up while using Altec Lansing IM600
Yes, the docking station is damaging the iPod. The vibration when used load is causing damage to the iPod. If you notice, the iPod will only freeze when it is playing load in the docking station. To avoid the problem, you'll need to play the music at a lower sound with less vibration. Once I began to play my music at more reasonable sound levels, I discontinued the problem. Very disappointing solution...but it is the answer. I too called Altec Lansing. They are not aware of this issue...I told them to search the internet - it's all out there.
Mar 21, 2009 | Altec Lansing Inmotion-IM600...
Top Altec Lansing Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Altec Lansing Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
