Replace telelock ts 90 base assembly - Televison & Video
Like to set digital timer.It's a Provalue TS-EA1
1) Copy following links for possible TS-EA1 timer manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
http://waterheatertimer.org/pdf/TS-EA1-digital-timer-manual.pdf
2) This is a new series of 50 Hz timers made for worldwide 230Volt market.
Manual was written based on other similar timers, and how those timer buttons worked, although there is not another timer with 1:1 same buttons.
3) Add comment and say what you discover when trying to program your timer. Then possible manual can change accordingly.
Jan 06, 2013 | Hardware & Accessories
Want to set timer on Provalue ts-EA1
Evidently there are several brand names selling TS-EA1 timer
Jan 06, 2013 | Sunbeam 6 Robinson Home Digital Timer
Mitsubishi TV Model TS-4557 Two problems: 1) The picture is very dark despite the brightness control being at the maximum. 2) The picture is fuzzy - particularly when there is text on the screen, to the...
the problem is picture tube base which connects picture tube to circuit board ..inside ur tv..take tecnical help of service men to replace the p.t.base
Mar 13, 2010 | Mitsubishi TS-4557 45" TV
Can I write Dual layer DVD with TS-H542A DVD±RW
Based on the specs i do not see support for a DVD R +DL.
Nov 14, 2009 | Samsung TS-H542A DVD±RW Burner
I got a response regarding the regulator however I cannot see it - where do i find a free diagram of the inside of the door where the motor is
  1. Remove the door trim panel and watershield.
  2. Remove the inside door belt weatherstrip and glass stabilizer.
  3. Remove the door glass.
  4. Remove the 2 nuts attaching the equalizer bracket.
  5. Remove the rivets attaching the regulator base plate to the door.
  6. Remove the regulator and glass bracket as an assembly from the door and transfer to a workbench.
  7. Carefully bend the tab flat in order to remove the air slides from the glass bracket C-channel.
  8. Install new regulator arm plastic guides into the C-channel and bend the tab back 90°. If the tab is broken or cracked, replace the glass bracket assembly. Make sure the rubber bumper is installed properly on the new glass bracket, if applicable. CAUTION
    If the regulator counterbalance spring is to be removed, make sure the regulator arms are in a fixed position prior to removal. This will prevent possible injury when the C-spring unwinds. To install:
  9. Assemble the glass bracket and regulator assembly.
  10. Install the assembly in the door. Set the regulator base plate to the door using the base plate locator tab as a guide.
  11. Attach the regulator to the door using new rivets. 1⁄4 in.–20 x 1⁄2 in. bolts and nuts may be used in place of the rivets to attach the regulator.
  12. Install the equalizer bracket, door belt weatherstrip and glass stabilizer.
  13. Install the glass and check for smooth operation before installing the door trim panel.
03b3db6.gif Posting a diffent one also because I don't know what your first original post was.
May 17, 2009 | 1993 Ford Explorer Limited
How to replace dvd rom drive.NO release button on base!
Firstly there is a screw on the underside of the laptop that needs to be removed.I ts is located on the edge of the drive.
Next the keyboard needs to be removed. To do this, remove the strip at the top of the laptop containing the power butto by inserting a small flat blade screwdriver at under it and prising it up.
After removal, undo the three screws holding the keyboard and flip the keyboard over.
Undo the screw that holds the keyboards strap securing plate and then slide the drive out.
Be warned though that not all drives work in these laptops. It has to be the exact type for the machine as most do not work.
Assembly is the reversal of the above.
Hope this helps.
Feb 08, 2009 | Toshiba Satellite Pro A10 Notebook
Changing headlamps on 2003 bmw 325xi
I am assuming that you have a burned out head light bulb.
1) Open hood.
2) Working in back of headlight assembly, grasp rear of bulb socket (harness connector) and turn counterclockwise 90 degrees. Pull bulb out of headlight assembly.
3) Disconnect harness connector from bulb (gently pry, it's plastic)
4) Installation is reverse of removal. (Do not touch halogen bulb with bare skin-oils from hand will cause bulb to burn out.) Align tabs on bulb base to cutouts on rear of lens assembly. (Note bottom tab is wider than other two) Secure bulb by rotating clockwise 90 degrees.
Low beam bulb H9006
High beam bulb H9005
Jan 07, 2009 | 2003 BMW 325
TREO 90 Backlight
The Treo 90 had a problem with backlight failure, which Handspring acknowledged and began fixing back in 2002.  However, their guideline was that if your 90 did not fail within 6 weeks of use, it did not have the defective part responsible for the failure.
Your backlight probably has just died of old age.  It is EXTREMELY difficult to replace just the backlight (I've tried).  If you search long enough on eBay, though, you can probably find a 90 with a broken case, dead battery, broken motherboard, or some other ailment, but with a functioning screen/keyboard assembly, including backlight.  It's a pretty simple matter to replace the screen/keyboard assembly (there's a screw hidden under the battery that holds it into the front frame).
May 15, 2008 | Handspring Treo 90 Handheld
Mitsubishi Projection TV Model TS 4573 not TS 4545
No if the problem is the screen, you will need to replace the entire screen assembly. some screens come in two parts. The inside of the screen is called the freznal lens, the outside of the screen is called the lenticular lens. Good Luck
Jun 05, 2007 | Mitsubishi TS-4545 45" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
