Question about Tasco Luminova 40076420 (420 x 76mm) Telescope
Jason comet chaser model 336 vertical micro adjuster
I need a vertical micro adjuster the threads into the handle twisted off
2 Suggested Answers
SOURCE: Jason Comet Chaser 335
your scope needs colimation
Posted on Mar 28, 2008
What are the adjustable handles?
Adjustable handles are ideal for manual adjustments and tool-free fastening or clamping in tight spaces, RoHs compliant Adjustable Handles (Clamping Handles) provide the positioning flexibility needed for limited space applications or additional operator comfort. Available in Zinc Die Cast or Nylon 6. All ICG Adjustable Handles can be ordered with tapped inserts or threaded studs with steel or stainless steel components.For more queries on the Adjustable Handles follow the link.
Sep 09, 2016 | UTG Model 4, 15 Carry Handle With...
Tip
Spark Plugs ( How to replace them)
Spark plugs on a car should be replaced every 2 years or 24,000 miles. To remove the plugs you need a ratchet and either a 13/16 or 5/8 inch spark plug socket, depending on your car's spark plug size. A universal-joint drive-handle attachment and extension attachments can help you reach awkwardly placed plugs. Fit the socket firmly over the hex section of a plug and with the ratchet set to unlock, apply pressure counter clockwise. Hit the handle with the heel of your hand to unseat a stubborn plug. If it continues to stick, use penetrating oil. If it takes effort from start to finish to unscrew a plug, clean the threads of the hole with a thread chaser before installing a new plug. Replace plugs with the brand and model number recommended by manufacturer or with a manufacturer's equivalent. If your engine has an aluminum head, apply a film of anti seize compound (available in tubes from auto parts stores) to each new spark plug's threads. Use a spark plug gauge to adjust the gap between electrodes of each new plug. (Refer to your owner's manual or gap specification on the decal under your car's hood.) The gauge should fit snugly in the gap. To adjust the gap, use the gauge's bracket to bend the L shaped side electrode. Recheck with the spark plug gap gauge. Thread each plug into it's hole by hand until it seats. If the plug has a gasket,m use the ratchet to tighten it quarter to a half turn more. If there is no gasket, only a sixteenth of a turn should be needed. Lightly apply silicon dielectric grease to the inside of the cable terminals: then push each terminal onto the nipple of its spark plug.
on Mar 01, 2010 | Toyota Tacoma Cars & Trucks
How to adjust Hand brake on 2003 Carnival Kia?
0n the handle end there should be a yoke and a pin conecting the cable to the handle the end of the cable usually has a stud off the end and the yoke is internally threaded . pull pin conecting yoke to handle grab stud with wrench and twist yoke it should be threaded turn it and it will thread in and shorten cable. give it a few turns in reassemble and test adjust as necessary
Oct 26, 2014 | Kia Carnival Cars & Trucks
What year was my Marlin 30-30 with serial number 6014444 made?
TRY THIS LINK
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
May 10, 2014 | Marlin 70510 336 Model 336 Lever 30-30 Win...
Knex comet chaser instructions
WERE WOULD I BE ABLE TO GET A COPY OF TE INSTRUCTIONS TO BUILD THE COMET CHASER
Mar 29, 2012 | K'nex Toys
Vertical picture problems on my 1993 mitsubishi vs-50va2
Can you provide a more detailed description of the vertical problem you are seeing? There are a number of defective parts that can cause different symptoms. Few vertical problems are adjustments. Most are either poor solder connections or defective parts. The parts cost should be minimal.
Please confirm you model number here and try to provide more details on the problem.
Thanks,
Dan
May 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Instructions and value
Probably will not find a manual-- value ? Next to nothing. Jason telescopes are considered to be toy telescopes.
Apr 04, 2009 | Optics
Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Feb 12, 2009 | Moen Castleby Two-Handle Widespread Roman...
Tasco Luminova 40076420 (420 x 76mm) Telescope Logo
37 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
