Question about Onkyo Tx-910 Quartz Synthesized Tuner Amplifier R1 Receiver
Power button not working
The unit stopped working. The power button does not turn on the unit even when depressed. This is a new problem that started recently. It is plugged in and receiving power fine (I checked the outlets and extension cords). Any suggestions?
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
Maybe its the fuse in the unit.
Posted on Feb 11, 2014
Eror 5B02 dan 5B03
This may work.
Press and Hold the STOP / RESET followed by pressing the POWER button. So both buttons depressed position. 3. Release the STOP / RESET but do not release the button POWER.still depressed state of the POWER button, press the STOP / RESET 6 times.
Apr 03, 2016 | Office Equipment & Supplies
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
SC-HC35DB DAB RADIO HAS STOPPED WORKING , ALL OTHER PARTS FINE ,
You need to tunr the power off at the wall socket. Leave the unit off for at least 5mins. Then whilst holding the power on button on the unit down, turn the power back on at the socket, keep the power button depressed for at least 5secs. When you release it you should see -----------------, in the display. The unit has just been reset to factory mode. All features should now be present again. Hope this helps.
May 02, 2012 | Panasonic Audio Players & Recorders
Three out of the five plugs do not work have stopped working.
The APC UPS will power the non-battery (label something like surge only) with the power button turned off. If the outlets that are not powering up are labeled Battery/Surge, you need to turn on the UPS. There should be a button you depress to turn the system on.
Also if this is a new UPS, you will need to hook up the battery for this to work. Open the bottom of the unit and you will find the battery and plugs.
Jul 20, 2011 | APC Back-UPS Office 500VA (BF500) UPS...
Unit was on battery power, shut down, connected to 12v p/s,let charge for a short while, then powered unit up, load bar completes but goes no farther.
MANUAL REBOOT TIME:
Plug unit in 110 power, then turn it off. You are going to manually reboot system. When unit is completely off, then turn on, but this time, when turn it on keep the on button fully depressed, do not let go regardless as the unit is turning on, and even when it is coming on going through its thing, keep on button depressed for 10 seconds after unit fires up. Then let go, and this is manually rebooting it, See if now it functions properly, Please let me know, and if fixed, then the 4 thumbs up for my solution with small comment is most appreciated. Thanks Mike,from fiya.com
Jun 14, 2011 | Magellan Maestro 4250 GPS
Left turn signal stops flashing when brake pedal is depressed.
there is a ground problem, most likely in the tail unit itself, but a ground problem is hard to find and easy to fix. reground the system, the turning unit, and the problem should stop. About the hazards, I don't know...... some times in older cars, that is the way it works. because the brake and hazard element in the bulb is the same and the old cars used a break in the power, but the new cars use a break in the ground. any way, chase the ground down first, it is usually the cause.
Feb 12, 2009 | 1999 Jeep Wrangler
My Garmin Nuvi 200 wont turn back on
Our Garmin didn't turn on. We unplugged it, pushed the reset button on the bottom and then plugged it in again and it WORKED
Aug 02, 2008 | Garmin nuvi 200W GPS Receiver
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Onkyo Tx-910 Quartz Synthesized Tuner Amplifier R1 Receiver Logo
83 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
