Question about Amazon Kindle Fire
Takes very long to charge fire
What mode should kindle be in when charging?? how about charging on computer??
  • 846 Answers
SOURCE: My kindle will not charge. I plug it in and there
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
Posted on Jan 17, 2010
  • 846 Answers
SOURCE: Kindle will not take a charge
Does the little yellow charging light come on when you connect it? If not try a different charger. If that fails too, you may have a logic board issue. Amazon should give you a greplacement. If you're out warranty. Try to power up your Kindle with a different battery. If that fails, you need a new logic board, and you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Posted on Jun 08, 2010
  • 846 Answers
SOURCE: The kindle screen is frozen on the sleep mode, the
Try a different charger. If that fails too, you have a logic board issue. Amazon2_bing.gif should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Posted on Jun 09, 2010
  • 457 Answers
SOURCE: kindle will not charge from out let or computer
Please clarify: what charger did you use to connect to an outlet? The Kindle 3 comes with an USB cable to charge from a PC or Mac computer and no charger outside for many countries outside the US (for other countries an external charger is available from Amazon as optional accessory). Use of a different charger (e.g. mobile phone charger with USB connector) is not supported, not recommended and may fry your Kindle if a wrong voltage is hooked to it.
Things you can try:
  1. Use a different outlet to charge the Kindle.
  2. If you use the supplied USB cable to connect to a PC, make sure its firmly seated on both ends. Connect to a powered USB port directly on your computer. Some external USB hubs do not come with a separate power supply (external power supply is mandatory for an USB 2.0 hub, some cheap models are sold without one anyway) and are not suited to charge anything. Just to make sure, disconnect any other USB device except mouse / keyboard to check if the USB port in use is not burdened by too much drain.
  3. The Kindle power LED should glow amber while charging and green if the device is fully charged.
  4. Give the Kindle a reset pressing Home --> Menu --> Settings --> Menu and select "Restart." If the charge light is on but the device is still not charging, contact Amazon customer service.
  5. If the charge light does not light, the AC adapter or cable needs to be replaced.
  6. Contact Amazon customer support for any warranty issues.
Posted on Jan 01, 2011
  • 457 Answers
SOURCE: Kindle light is orange when
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Posted on Jul 23, 2011
Testimonial: "Nope, nothing. I tried plugging the usb into my laptop. The Kindle doesn't show up or it says no data/driver found."
Kindle fire
Defective battery, if the battery will not take a charge the AC adapter will not run the tablet (not enough power) by its lonesome.
Oct 21, 2016 | Tablets & eReaders
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kindle Fire Won Charge Fix
12 major Kindle Fire problems and how to fix them
Reset Kindle Fire When it Won Turn on or Charge
Apr 08, 2016 | Amazon Kindle Fire HD
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
Dec 25, 2015 | Amazon Kindle Fire HD
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
More results from www.amazon.com
Dec 09, 2015 | Tablets & eReaders
How do I get the back off to replace battery on my kindle fire
Judi this is not a consumer replaceable battery , take it to a computer shop
Oct 17, 2015 | Amazon Kindle Fire HD
How long to charge kindle fire hdx when new
It should take under 6 hours for a full charge.
Feb 19, 2015 | Amazon Kindle Fire HD
My kindle will not charge?
The Kindle Fire HD, if completely discharged, may take several hours to begin to accept a charge again. Simply leave it plugged in long enough and the on-board system will sort it out.
Feb 01, 2015 | Amazon Kindle Fire HD
Why wont my kindle hd charge?
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
Jul 23, 2014 | Amazon Kindle Fire HD
My kindle fire will not turn on
Maybe try taking it where you got it or take it to a computer store. Maybe it could be dead. Try charging it.
May 12, 2014 | Amazon Kindle Fire HD
Amazon Kindle Fire Logo
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
