Question about Softheat Heating Pad HP218 12 3P
Heating pad blinking light
When I select any heat range the top green light starts to blink. I have unpluged the equipment and tried several types of on and off procidures nothing works
Z52DC2D WILL NOT TURN ON..GREEN LIGHT BLINKS, THEN RED TEMPERATURE LIGHT BLINKS THEN BACK TO GREEN LIGHT BLINKING THEN TURNS RED (OFF)
Check the below linked site for more details about the blinking codes. Blinking codes and fault location procedure to many brand TVs are given.If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
Apr 30, 2013 | Zenith Televison & Video
How to repair TV, green light blinks then red temp light blinks then back to green blinking light?
If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Apr 30, 2013 | Zenith Z42PX2D Television
Light is flashing on temperature control of heating pad
Trust me! This thing is a piece of ****! I bought one and loved the heat options that I bought three more for my wife and two daughters and their families. The next day mine went out. Took it to Walmart and traded it for another. Still pretty happy, figured I got a bad one. Three months later not a single one is working all have blinking green lights and won't allow you to do ANYTHING but unplug it! Five and all died the exact same death. Go to Walmart and each time they act surprised! NO WAY!!! This is a chronic problem with this product. I'm contacting the company tomorrow and am going to demand an ecplaination as to why they have not take this item off the market!
Jan 07, 2012 | Softheat Heating Pad HP218 12 3P
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
Have heating pad model 818-7. blinking red light for high when connected- but no heat. what to do. I love this soft, terry cloth hour glass heating pad controller model number: SW204. e12107 is also on...
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
Dec 16, 2009 | Sunbeam 805810 HeatSense Heating Pad...
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
New heated mattress pad won't warm up. Controls keep blinking.
i've lost my control for a king size electric blanket. it had dual control-can u tell me where i can get one and the cost. thx
Dec 13, 2008 | Sunbeam SG7621SP Grill
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Softheat Heating Pad HP218 12 3P Logo
100 people viewed this question
Top Softheat Health & Beauty Experts
Securetech...
Tom Chichester
Are you a Softheat Health and Beauty Expert? Answer questions, earn points and help others
