Now it wont reprogram and the Check engine, Oil Level, and Battary lights are on on the dash as well. I have tested all fuses and relays and tried every form of PATS reprogramming I can find, Any other Ideas?
SOURCE: 2007 mercury milan V6 Car wont start. Jumped it
Remove the lugs at the battery. Clean the posts and the lugs - then reconnect. Your battery won't charge (and the jumpers won't work) largely because of a film on the + post and lug. If you live in a hot summer area, (Arizona) the problem is especially troublesome.
SOURCE: 2007 Mercury Milan Premier V6 ac compressor clutch
you may need to top up the coolant,r112,r140or what ever the car is useing. if the car can'nt be topped up then you have a leak that needs to be fixed,usually the drier.
SOURCE: The under dash fuse box cover has been removed!I
I suggest check the 2001 Mercury Sable - Owners Manual (page 139 and next)...
Hope help with this (remember rated and comment this).
SOURCE: where is the fuse box
passenger side this might help, Tim;
http://carwiringdiagrams.net/2007-mercury-milan-passenger-compartment-fuse-panel-and-relay-diagram/
