Question about DuroMax Duro Max XP8500E-CA 8500W 16 HP Generator Electric/Wheels CARB
Diagram for fuel line connections?
I am looking for a diagram for the fuel line and vapor lines connections.
Looking for fuel system diagram
Chances are its what is called the fuel pressure regulator is the problem.
These other systems have vents and valves and are disgined them selves .
The pressure regulator deals with the fuel injecters mainly back pressure feed back to the tank .
The vehicle will run OK but when you shut it off you smell gas vapor it has to get out .
Mar 26, 2015 | Cars & Trucks
Vacuum. Diagram for a 2002 jeep grand cherokee 4.0
On 4.0L 6 cylinder engines, a molded vacuum tube connects manifold vacuum to top of cylinder head (valve) cover at dash panel end. The vacuum fitting contains a fixed orifice of a calibrated size. It meters the amount of crankcase vapors drawn out of the engine.
On 2.5L 4 cylinder engines, a fitting on drivers side of cylinder head (valve) cover contains the metered orifice. It is connected to manifold vacuum.
A fresh air supply hose from the air cleaner is connected to front of cylinder head cover on 4.0L engines. It is connected to rear of cover on 2.5L engines.
When the engine is operating, fresh air enters the engine and mixes with crankcase vapors. Manifold vacuum draws the vapor/air mixture through the fixed orifice and into the intake manifold. The vapors are then consumed during combustion.
Mar 08, 2015 | Jeep Cars & Trucks
Diagram for gas tank hoses on 1999 oldsmobile bravada
It depends on which one is leaking. You should have two fuel lines from the pump plus two or more lines for the vapor recovery. The lines for the pump are under 50-70 PSI.
I don't have a diagram.
Jun 26, 2012 | 1999 Oldsmobile Bravada
Vacuum diagram for a 2004 tiburon
There is only 4 vacuum lines on that engine
1- brake booster line
2- purge line to purge solenoid (top center of throttle body)
3- PCV hose. run straight from PCV to side of intake at base of throttle body
4- fuel pressure regulator line (short small diameter hose runs from #6 intake runner to fuel pressure regulator
5- tube that connects front cam cover to rear cam cover to improve vapor venting
http://www.hyundai-forums.com/attachments/gk-tiburon-coupe-s111-2003-2008/38204d1276396353-vacuum-lines-2004-tiberon-pict0001.jpg
Jun 25, 2012 | Hyundai Tiburon Cars & Trucks
Locate fuel filter on 2005 ford focus tdti
Ford Focus 2000-05
Removal & Installation
Print
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE The fuel filter is located underneath the vehicle in the area of the rear suspension.
  2. Relieve the fuel system pressure.
  3. Raise the vehicle.
    NOTE To remove the lines, press the quick-release tabs on the connectors.
  4. Remove or disconnect the following:
    Evaporative Emissions (EVAP) vapor line Fuel filter lines Fuel filter and bracket assembly Fuel filter
    Fig. Location of fuel filter and lines.
To install:
  1. Install or connect the following:
    Fuel filter Fuel filter and bracket assembly Fuel filter lines EVAP vapor line
  2. Start the engine and check for leaks.
  4. Remove the fuel filter bolt and remove it from the bracket.
To install:
  1. Position the fuel filter into the bracket. Ensure the fuel flow direction is properly aligned.
  2. Install and tighten the fuel pump bracket bolt.
  3. Lubricate the fuel tube fittings with clean engine oil. Align the fuel tube fittings and press together until a click is heard and then pull on the fittings to make sure they are fully engaged.
  4. Start the engine and check for leaks
May 09, 2012 | 2005 Ford Focus
Vacuum diagram for a 1994 mustang 5.0
This was the best I was able to come up with. Now there is the vapor/vacuum for the fuel system as well as vacuum lines for the A/C system but didn't know is you needed thoses as well. Hope these help.
Jan 17, 2012 | Ford Mustang Cars & Trucks
Un connected vacum line,apprx.6'' long,cannot find where to connect,looked everywhere within lengt of line.97 sentra vacum skamatic diagram needed.causing chk.eng.lite to come on.p0440.purge...
Hi Michael: here you have two diagrams...
DTC P0440 code indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
A code P0440 could mean one or more of the following has happened:
  • The gas cap is not installed or working properly
  • The purge solenoid has failed
  • The canister is plugged and not working properly
Additional details could find in this links Fault Codes on Cars & Trucks or other diagrams in Cars & Trucks Vacuum Diagram.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 07, 2011 | 1997 Nissan Sentra
Im looking for a fuse box diagram for a 2001 buick lesabre for the rear seat with the vapor line electrical harness attached
The vapor line will never be inclosed inside of the automobile. Electrical lines YES.
In the rear of your auto you have back up lights, tail lights, turn signal lights, LC plate lights. may truck release switch wire, speaker wires, and the emergency fuel shut of switch. If the vehicle is in a front end/back end accident it will tripe the fuel safety switch. It is a red button located in the trunk panels. GB..stewbison
Aug 31, 2011 | Buick LeSabre Cars & Trucks
Ive got a 96 ford taurus gl that im working on. they put gas in drove it home and now it wont start. i looked under it and could see fuel leaking out of the vapor canister whenever tried to start. could a...
Hello! The vapor canister is more than likely plugged...The carbon granules can infiltrate the entire fuel system...I would suggest #1...Replace canister...and fuel filter..#2....Relieve fuel pressure, disconnect battery, remove and clean the fuel rail and injectors...On 8/12/1996 there was a recall on your vehicle addressing the fuel and injection system...If the recall was performed there should be a sticker on the inside of the drivers door...The original culprit is the Fuel Vapor control Valve which is allowing fuel to enter the vapor lines...see diagram below...
Fuel Vapor Purge Valve:
MOTORCRAFT Part # CX1687 Cost $80
Guru.................Saailer
Aug 28, 2011 | 1996 Ford Taurus
2000 ford focus in line fuel filter where is it located
Hi, it's back by the fuel tank.
NOTE: The fuel filter is located underneath the vehicle in the area of the rear suspension.
  1. Relieve the fuel system pressure by removing the fuel pump fuse from the battery junction box, starting the engine, and allowing the engine to idle until it stalls.
  2. Raise the vehicle.
  3. Remove or disconnect the following:
  5. Fig. Location of fuel filter and lines.
To install:
Mar 31, 2011 | 2000 Ford Focus
DuroMax Duro Max XP8500E-CA 8500W 16 HP Generator Electric/Wheels CARB Logo
26 people viewed this question
Top DuroMax Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a DuroMax Electrical Supply Expert? Answer questions, earn points and help others
