Question about Samsung LN32B360 32 in. LCD HDTV
Identifying a blown fuse - Samsung LN32B360 32 in. LCD HDTV
How do I find the light circuit fuse, How would I know if a fuse has blown, none of the fuses have popped up?
Use the owners manual to locate the fuse it will give the correct fuse to use . All fuses have the amp rating stamped on them. A good fuse will have the fuse wire intact. Headlights sometimes use a circuit breaker rather then a fuse.
Sep 03, 2016 | Cars & Trucks
I have a 2001 Mazda Mellinia, the a.c. fuse is blown, what kind of fuse will I need and where is it found in the fuse box
If you do not know where it is or what it looks like than how do you know it is blown?
It is not difficult to visually look at a fuse to see whether or not it is blown. a visual inspection can be done with a flashlight and without removing any fuses from the fuse block. A blown fuse will typically have a black spot and an open in the wire between the two posts.
A test light can also be used to quickly identify blown fuses. if one side has power and the other side does not the fuse is no good.
Your owners manual will also help you identify fuses. In the back you will find the index. Look under fuses and it will give you the page numbers. If you do not have an owners manual one can typically be downloaded on the manufacturers website. Just look for an "owners" link usually near the top of the page.
Sep 06, 2015 | Mazda Cars & Trucks
Where is fuse for lighter
Year, Make, Model, and Engine Size?
Have you consulted your owners manual?
a blown fuse is pretty easy to identify by sight, did you inspect all the fuses?
Mar 01, 2015 | Cars & Trucks
Fuse box ]
If you suspect you have a blown fuse somewhere,
Instead of wasting time searching for the exact location, why not just remove each fuse 1 by 1, and replacing them as you go so you don't mix them up. If you have any blown fuses, you will find it in under 30 seconds. If you don't know the difference between a good vs blown fuse, ill post a picture to help you identify.
Dec 08, 2013 | Toyota Pickup Cars & Trucks
What does each fuse goes to in each fuse box?
If you suspect a blown fuse, i suggest that:
If your car has the round clear fuses with metal caps on each end, then blown ones will be burned black.
Dec 08, 2013 | 1985 Ford Tempo
The lights an radio an wipers, horn,nothing want work on a 1995 j30 infiniti
Check your fuse box. When multiple things fail at the same time it is usually a blown fuse. Extremely easy and cheap to fix. Probably a dash fuse, on a 95 infinity the fuses should be easy to identify by looking at the referance guide on the back of the fuse box cover. If it doesnt have a reference guide you can check your fuses one by one, You can identify a blown fuse by inspecting the contacts for a damage. If you find a blown fuse be sure and replace it with the same type.
Jun 29, 2012 | Infiniti Cars & Trucks
Hello I need help identifying which fuse i need to replace. The radio and cigarette lighter no longer work
The fuses should be identified on what they are for. Check the center of the fuses and if there is a separation in the middle, may be a dark spot, the fuse link is blown.
Aug 27, 2010 | 2002 Mazda Protege
Radio fuse has blown need to know which one it is
there should be a 'legend' on fuse box cover identifying locations specific to your model.blown fuses are readily identified when removed & inspected. after market radios usually have an 'inline' fuse on the power supply wire as well.
Oct 17, 2009 | 1997 Mercury Grand Marquis
Power accessory outlet for 2005 Honda CRV
I have (had) a 2006 CR-V with the same problem. The identified fuse for the outlet (#18) was not blown. However, there is a fuse identified as "+BR ACC" (fuse #15) that was blown. Both are 15AMP fuses located in the fuse box under the steering column. Replaced the #15 fuse and the outlet is working just fine.
Mar 09, 2008 | Car Audio & Video
Samsung LN32B360 32 in. LCD HDTV Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
