Question about SUBURBAN MANUFACTURING C Surburban Water Heater -6 Gal Sw6p-Gas W/Pilot-Very Popular - 5054A
Surburban sw6p pilot adjustment
How do you adjust pilot light
    Top Expert:
  • SUBURBAN MAN... Master
  • 8,694 Answers
If good pressure from regulator and clean assembly and burn tube shouldn't have to adjust check pressure from regulator
Posted on Feb 11, 2018
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
How do I find adjustment screw for pilot light on 1998 white rodgers hot water gas 6 gallong
most pilot's are not adjustable. if it is not staying lit, replace the thermocoupler.
Jan 06, 2015 | Water Water Heaters
Suburban hot water heater sw6p shooting out flames
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Dec 03, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
My White Rodgers Gas Valve 37C72U keeps going out. It burns well for ten to twenty minutes and then just shuts off. It lights first press but goes out again after the above time. All flames appear good....
have you replaced the thermocouple connected to the gas valve?if they get bad they will shut off gas flow,and no you cannot adjust the pilot flame size which is controlled by the valve also
Mar 27, 2011 | Water Heaters
Adjust pilot light on hot water heater
On most water heaters there is no adjustment to pilot light. About the best you can do is clean pilot and burner. If you are having trouble keeping pilot light lit then I would replace the termocouple.
Nov 16, 2010 | Water Heaters
Atwood gas waterheater with white rodgers gas valve pilot hard to light and not a big enough flame to touch the thermocouple
I think you need to reposition the thermocouple, or adjust the pilot gas pressure by adjusting the pilot screw make sure it is still the recommended gas pressure of the system... please contact a HVAC tech if this things did not work.
Aug 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
My hot water has gone off. It was working this morning and the pilot light has not gone out. How can I check for other explainations?
The pilot light is working so you know you have gas but you also know that the gas is not coming on. The pilot flame should be bright blue with the tip of the flame having a ting of yellow. A yellow flame is caused by a dirty pilot tube tip. Split flame is caused by dirt in the pilot tube. If the flame is not hot enough it will not tell the thermocoupler to turn the gas on. If the thermostat has not been moved and is still at the correct setting then I would suspect the thermocouple is bad. The thermocouple is mounted right next to the pilot light. It senses if the flame is hot enough for the gas to come on. If the pilot flame is not touching the coupler then it will not allow the gas to be turned on to the burner. Check the thermocoupler and see if the flame is touching the probe on the end. If not adjust it until the pilot flame is touching the coupler. If the flame is properly adjusted then replace the thermocoupler but shut off the gas supply before doing so. It will look like this. 0ec43e2.png
Apr 25, 2010 | Water Heaters
Gas (LP) Valve/ Thermostat Adjustments
that is the flow to the pilot lite and no it is not supposed to be readjusted, if anything you should get the numbers off the gas valve and replace it, or depending on the age of the water heater get a new one,
May 25, 2009 | General Electric GE SmartWater Household...
Adjust pilot light
Adjust? What do you mean? The flame relationship to the T-couple? Or is the flame too low?
Low flame can be adjusted on some gas valves but mostly it requires special tools and knowledge of the gas valve. Most times it's a sign the GV is going.
Mar 01, 2009 | Water Heaters
SUBURBAN MANUFACTURING C Surburban Water Heater -6 Gal Sw6p-Gas W/Pilot-Very Popular - 5054A Logo
424 people viewed this question
Top SUBURBAN MANUFACTURING C Water Heaters Experts
Paul Carew
Gil Shultz
Are you a SUBURBAN MANUFACTURING C Water Heater Expert? Answer questions, earn points and help others
