Question about Panasonic Televison & Video
How do I disconnect the sc45 and sc46 connectors on my Panasonic sc board
2 Suggested Answers
gopakumarg43
  • 74251 Answers
SOURCE: tc-p60st50
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 26, 2016
Tc-p60st50
Aug 25, 2016 | Televison & Video
I have a black screen with 7 flashing lights.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 05, 2015 | Panasonic TC-P55ST50 viera tcp55st50...
Cannot print
E5- 11 Printer Engine Communication
Abnormal
1. SPC PCB connector disconnected.
2. SPC PCB defective.
3. SC PCB connector disconnected.
4. SC PCB defective.
Nov 18, 2013 | Panasonic DP-8016P Copier
UNIT WILL NOT POWER UP / NO FROUNT LIGHT / NO RELAY CLICK / HAVE CHANGED POWER SUPPLY BOARD ALREADY
if you change power supply then make sure it working check for stby 5 volts and check volts on power switch if voltage are there then power supply may be good. try to disconnect connector or sc board and ss boards. both on side of the tv then turn on the tv it will give you click turn on tv you should hear somr sound if not then your main board is defective if tv come on when disconnect the ss or sc boards then one of them boards are defective
Dec 03, 2011 | Panasonic TH-42PD60U Television
I have a Th-50PC77U that doesn't turn on. Relays will click and start to power up but then it goes into safe mode and the power LED blinks 7 times. Is there a circuit board i can replace to fix this?
& blinks is sc or,sd or ,su board or all 3. Disconnect the ac cord. remove the back cover. on the left are 2 thin boards with flat cables that connect to the panel. these 2 boards are the SD and SU boards. They are connected to a board to the right. This the SC board or Y sustain board. Disconnect the 2 wie plug that connects this SC board to the power board in the middle. Examine the sqauare ics on the SC and SU boards on the rt side. Look for a pit or burn mark on one of the ics. If you see one then this board is bad. Disconnect this board from the SC board remove connectors on the rt and also remove the all the screws on this board. It should now be hanging free only by the flat cables on the rt. reconnect the 2 wire cable from the SC board to the power board. Plug in the set and power on. If set turns on the that board needs replaced. You will see 1/2 of picture. If still won,t turn on then disconnect the ac cord and the 2 wire conn from power board to SC board. disconnect the other board on the left letting it hang free. re connect SC to power board,plug ac cord in and turn on. If set now will turn on then Replace that board. If stiil won/t turn replace the SC board.
Sep 08, 2011 | Panasonic TH-50PX77U 50 in. Plasma HDTV
TH42PZ85U Panasonic that will turn on for a couple of seconds, not even long enough for picture, then it shuts off. Red power light blinks 2 times with about 3 seconds in between the 2 blinks. I am...
1. Reseating the connector P25 may solve the problem. If it does not.
2.Right before the unit shuts down, check the VSUS voltage at connector P2 of the power supply. If VSUS voltage measures zero volt, disconnect the connector P2 and SS11. Check the VSUS level at socket P2. If it is still low, replace the P board.
3. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
4. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
The screen is totally blank when the tv is switched on. Also, a red light at the front of the tv blinks 7 times before pausing for a few seconds and then repeats. I have checked all connections and tried...
Missing Vsus. Abnormality of the scan circuit output, the 15V_F, the scn_pro, and Vscn circuit. Loose or open Connection between the SC board and the SM board (SC41, SC42, SC46). Open or loose connection between connectors SC2/P2 Wrong diagnostic by the A board Defective panel
Feb 19, 2011 | Panasonic TC-P42G15 Plasma TV
WHY MY panasonic tc-50ps14 IS BLINKING A RED LIGHT 11 TIMES AND HOW I CAN FIX IT?
I have a 10 blinks and 12 blinks for that set, 10 says it possible SC board, and 12 says
Unplug the TV and disconnect connector A11 from the A board. Plug in the TV and press the power switch
Does the TV power up and
stay on?
No
Yes
If the speakers wires
are not pinched,
Replace
the speaker
Replace
the A board
Jan 16, 2011 | Panasonic TC50PS14 Plasma TV
ERROR CODE SC45-20
HAVING A REPORT CODE SC 45-20 HOW TO SOLVE IMMEDIATELY FOR PRINTER/COPIER BIZHUBPRO C500
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Televison & Video Logo
14 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
