Question about Eureka 3276AZ Pet Lover Bagless Upright Vacuum
Changing vacuum belt
Can't figure out how to get top separated from bottom.
  • 3 Answers
You have to turn the vacuum over and remove the two small silver screws on the sides of the bottom plate.
Posted on Mar 04, 2014
How do i change the belt on the eureka 4703D
Changing the belt is quite easy on this unit.
First, you will need a phillips screwdriver looks like the X. there should be 2 screws on the top cover, and then MAYBE one more there by the hose where it attaches to the base at the back. The top cover comes off and you have full access to the belt underneath.
Also, side note, once you have the cover off there you should see a black and yellow sticker near where the belt rides, and it will go into more details to changing the belt.
Nov 03, 2010 | Eureka Power Plus 4703D Bagless Upright...
How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Instructions on changing a belt on an Elite Hoover Vacuum Cleaner Model # v5075-930 Serial # 089500053577
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=825812
Generic problem for all Vacuums
Posted by ed_maxwell on Jul 24, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 24, 2008 | Vacuums
Changing belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700198
Changing belt
Posted by Tribbles007 on Jun 23, 2008
Changing belt
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally there are 2 to 4 screws or clips, levers on the bottom of the vacuum, and then you can remove the bottom plate or top cover and then you can get @ the belt to change it. Unfortunately, I do not know the brand name and model& serial 3 in order to tell you the exact method for the belt change. You can check with your local vacuum cleaner dealer in your area or contact the vacuum factory tech support line. Such as: Example….
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Changing the belt
If this is a Savvy, then take out the screws for the bottom plate, then remove the screws that hold the top on, turn the vac over, and remove the Hovver emblem, there is a screw there, then the top cover comes off and you can replace the cogged belt.
May 31, 2008 | Hoover U8185-900 Upright Vacuum
Belt
You need to take the top cover off to get to motor shaft. Some had a couple of screws from the bottom, others had tabs, use a flat blade screwdriver to fit into the slots at the bottom edge of the top, pry out and up to pop the cover off.
Mar 08, 2008 | Hoover Commercial C1403 Bagged Upright...
Changing belts
Turn vac over, remove the 4 screws holding the bottom plate covering the brush roll. There are 2 belts, one is a V belt ( 38528034) for the brush roll, the other is a flat belt (38528035) that goes from the larger pulley and the motor shat, put it on the motor shaft then stretch it to go over the pulley.
Jan 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing a belt
Take off the bottom plate, look in the bottom to see if there are any screw, could be 2 of them, then from the bottom there is a slot on each side of the top cover, using a flat screwdriver, insert blade into the slot and pry up to release the locking tabs. Belt # is 38528040. Put the bell over the brush roll, put belt thru opening and put atound the motor shaft, put back together.
Jan 22, 2008 | Vacuums
Changing belt on vacuum cleaner
If you can't see the motor shaft then you will have to take the top cover off. Some have a couple of scres to remove from the bottom. Then is a slot on each side, from the bottom put a flat blade screwdrive in the slot and push out and up to release the locking tabs. The knob may pop off so watch for that coming off. Put the belt on the brush roll, then feed the belt up thru the opening and stretch it to go over the motor shaft. Put back together.
Jan 20, 2008 | Vacuums
Changing belt on hoover runabout
Found this info on the web...haven't tried it yet
Sep 07, 2007 | Vacuums
Eureka 3276AZ Pet Lover Bagless Upright Vacuum Logo
78 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
