I have the same problem, with my Ge 7-5295 radio, but there is nothing about an alarm in the manual, just a timer. The manual shows how to set the timer but no troubleshooting for it. Mine goes off every midnite sharp at 12:00. It will beep until I shut it off, turn on the radio or unplug it. There is nothing else I can do. It is very frustrating to say the least.I have the same problem, with my Ge 7-5295 radio, but there is nothing about an alarm in the manual, just a timer. The manual shows how to set the timer but no troubleshooting for it. Mine goes off every midnite sharp at 12:00. It will beep until I shut it off, turn on the radio or unplug it. There is nothing else I can do. It is very frustrating to say the least.
You can't post conmments that contain an email address.
Reboot the machine, including taking out the batteries. Don't know what causes it, but that's the only way mine stopped, and I'm never touching the Timer button again, because I think that's what got the problem started.
I had something similar and when all was said and done I found mice had crawled up into my air intake and were living in my dash chewing on my electrical wiring harness. I thought my car was posessed by ghosts or something.
factory security does not have toggle switches as far as I know so it is probably an aftermarket system. Try one of two things, turn the toggle switch the oposite direction with battery disconnected. Reconnect the battery and try again, the horn will beep a few times when you reconnect. try starting. If that doesn't work, disconnect the battery and turn the key to the on position and reconnect the battery and the horn will sound but will go off get in the car and try to start. It should start and run normally. shut car off, then you should be able to return the toggle switch to the previous position If this happens again turn the toggle switch to the opposite position with the batterry disconnected and turn the key switch to the on position and reconnect the battery and start when started go see a service that installs aftermarket systems and they should be able to reset it security system Hope this helps
It does have an alarm. Press and hold the third button for approximately 10 seconds. This will enter the alarm function, at that point press one of the upper buttons to turn alarm symbol off...
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy
"www.armitron.com/watch_instructions.asp" into your search engine and
you will see a list of illustrations of watches and associated instructions.
Choose
the one that looks like yours and download the PDF file.
You can download the complete user manual by clicking this link
You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
