Question about Motorola Mobility RAZR V3m Cellular Phone
Announce incoming calls - Motorola Mobility RAZR V3m Cellular Phone
Calling number doesn't announce or show on phone
most phone companies you have to pay extra for caller ID
Oct 12, 2017 | Lands Phones
Why does my telephone ring back after a conversation?
sir, you must be fooling by someone or check your phone settings. see the ring back tone settings or see the bottom of your phone. hope that helps sir!
CHARCOIS
Aug 16, 2008 | Lands Phones
How can i turn off call announcement feature?
go into your settings & tools then go to sound settings and scroll down to driving mode and set your driving mode to off and that should fix your problem.
Feb 05, 2016 | Samsung Convoy Cell Phone
How do you stop phone from announcing calls?
Hi John,
How to Announce Calls off a Pantech Burst ?
1.Press the "Menu" key, and then tap the "Apps" option on the Galaxy SIII home screen to launch the Apps screen.
2.Select "Settings"to open the Settings app.
3.Click the "Language and Keyboard" from the list of options.
4.Scroll down the screen and then tap "Text-to-speech output."
5.Slide "Driving Mode" to switch it from "On" to "Off.The setting is saved.
The Pantech Burst cannot read out a variety of incoming communications, including calls, messages and emails.
May 06, 2014 | Pantech Ease Cell Phone
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Not recording
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only)
3) Press the OK soft key. You will hear a confirmation tone.
Feb 02, 2009 | Uniden TRU8885 Digital Answering Machine
Answering machine has an "a" and will not record incoming phone calls when we are not at home.
Your machine is set to the announce mode, where it plays an outgoing announcement but does not record incoming messages. You want to switch it to the record mode. Since you declined to specify the model of your VTech system I can't tell you exactly how to do that. I can direct you to enter the model number into the search box here to download a copy of the manual.
Jan 23, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Voice command on incoming call
i cant hear anything when i answer my calls
Jan 17, 2009 | HTC Verizon XV6700 Cellular Phone
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Volume of incoming calls
Press the down arrow under 'Volume' on the base unit. The handset volume is in the middle and has a down arrow on the bottom of the large silver button.
Aug 24, 2008 | Panasonic (KX-TG1032S) Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
