Question about Maxi-Cosi Maxi Cosi Mico Infant Car Seat Lapis Blue
Is the maxi cosi combatible with a dodge grand caracvan
Need to hire a 7 seater car. Does anyone know if the maxi cosi Axiss or Tobi are combatible with a Dodge Grand Caravan or similar 7 seater model?
  • Maxi-Cosi Master
  • 1,629 Answers
Hi Lisa
Please contact Maxi-Cosi customer care team USA & Canada for assistance - Is the maxi cosi combatible with a dodge grand car - 380c2c95-927b-443b-80ce-6a556ec98186.jpg
Posted on Apr 24, 2014
  • 419 Answers
SOURCE: Maxi cosi tobi plastic part replacement
If you contact www.maxi-cosi.com you will be able to order this part.
I hope this helps.
Posted on Sep 15, 2009
  • 419 Answers
SOURCE: my daughter is only 18lb's but seems too tall for
You should keep your child in her Cabrio carseat unless she exceeds 13kg OR her head is higher than the back of the carseat. Make sure that you have removed the newborn support and head hugger too as this can free up a lot of space.
If she is too tall for the Cabrio and is at least 9kg and can sit un-aided for 20 mins, she can move up to the next seat (group 1), this would be the axiss.
I hope this helps.
Posted on Nov 15, 2009
Dorel UK
  • 1629 Answers
SOURCE: need instructions for adjusting straps
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Posted on Jul 21, 2011
Babycare_nl
  • 21 Answers
SOURCE: maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Posted on Sep 29, 2011
andrew336
SOURCE: pulled tensioner on maxi cosi tobi now i cant
Just did it. It took two of us, but only a couple of minutes and no tools (except a table knife) once we'd worked out what the problem was. The reason the strap doesn't thread easily through the slot is that there is a sprung two-part mechanism that needs to be held open. One person threads the strap through while the other keeps the mechanism open.
Person 1:
1) Find the slot under the chair that the strap goes into - turn the seat upside down; it's a thin gap you can feel with your fingertip when you run your finger along the narrow back of the metal strip under the front of the seat (not the base).
2) Remove the metal rod that attaches the grey reclining lever. The rod is about 20 cm long and can be pushed out without tools. Removing this rod seems to make it easier to open the buckle mechanism. When replacing the rod later, you just have to line it up carefully with holes (we used a torch to help us see them)
3) Make sure the strap passes under the metal rod at the bottom of the seat back (you can see how here in a small photo here: http://www.englishforum.ch/attachments/sale-wanted/37565d1327058634-sale-maxi-cosi-tobi-car-seat-9mths-3-yrs-zh-maxi_cosi_tobu_small.jpg)
Person 2
4) Push back buckle as far as it will go (it goes back past vertical easily, then needs another firmer push,
5) Hold the buckle in this backwards position.
6) Insert a table knife (rounded and blunt, not sharp) into the space under the buckle and push back the sprung, hinged plastic part that the knife touches at the back.
7) Person 1 then threads the strap back through the slot, pushing until then end comes out.
8) Tie a knot in the end of the strap so you don't accidentally pull it through again!
9) Replace the metal rod in the reclining mechanism.
10) Done!
Posted on May 19, 2012
Need a replacment fabric for my maxi cosi Axiss
Hi Cheryl - If you're in the UK you can order replacement fabrics via your local Maxi Cosi retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. Replacement fabric sets are RRP 60BGP and if ordered direct there will be 3.99GBP p+p additional. If you're outside the UK please visit www.maxi-cosi.com and select the country you're in, then go to the "Contact Us" tab
Nov 26, 2011 | Maxi-Cosi Axiss Reflection Booster Car...
Maxi cosi tobi strap has jammed
I hope this helps.
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
How to remove cover from axis car seat to be washed
Good Afternoon
The instructions for removal of the fabric can be found in the instruction manual. If you have lost your instruction manual please go to www.maxi-cosi.com and select the Axiss carseat to download a replacement instruction manual.
Jul 17, 2011 | Maxi-Cosi Axiss Reflection Booster Car...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Is it possible to purchase somewhere the white polystyrene inserts on around the headpiece of a maxi cosi toby? Many thanks. R
Good Evening
You can order the replacement polystyrene inserts via most authorised Maxi Cosi retailers or direct with our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm)
Jan 08, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to alter the straps
how to adjust straps in maxi cosi tobi
Jun 16, 2010 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
My daughter is only 18lb's but seems too tall for the maxi cosi cabriofix. when can she move in to her maxi cosi axiss???
I hope this helps.
Oct 24, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
I hope this helps.
Aug 17, 2009 | Maxi-Cosi Baby Gear
The new maxi cosi axiss
i have had this car seat for 18 months and i think it is brill! i have 5 children so i have had many car seats and this one is the best one iv ever had,well worth the money!
sally
Feb 07, 2009 | Basic Comfort Baby Gear
Maxi-Cosi Maxi Cosi Mico Infant Car Seat Lapis Blue Logo
122 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
