Question about Toshiba TheaterWide 52HM94 52" Rear Projection HDTV
Toshiba 52hm94 - Bulb replaced/no picture - How to test ballast?
How can I check to see if the ballast is bad?
  • gc01 Sep 12, 2008
    My 52HM94 seems to be going through bulbs much too quickly.
    The rated life for the bulb is 2000 hours.
    I operate the unit according to the user manual.
    The current is not cut off when I turn the unit off (the on-off indicator blinks for a few minutes after turning the unit off)
    I have had the unit 4 years and I have just installed the 5th bulb. On average, I would say that we use the unit less than 15 hours per week (780 hours per year).
    I have been told that the ballast may need replacing... Another $250 service call... Is this going to fix the problem?
ctf1800
  • 4402 Answers
SOURCE: Yellow blinking status light
I would make sure you have it seated correctly into the ballest some times the connector will come undun
Posted on Jan 18, 2008
  • 4234 Answers
SOURCE: Toshiba Ballast part number
Use the following part number: 23122468. The cost is $48.38 from TRITRONICSINC.COM
Dan
Posted on Mar 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Apr 30, 2009
mbelectronic
  • 147 Answers
SOURCE: Need to replace the ballast on a 52HM94
the ballast is a small rectangular board.it is very easy to change.remove the lamp and you
will see a plug where the lamp plugs into.remove the two screws on that plug.then
remove the 4 screws holding the ballast in.remove the ballast and install the new one.
Posted on Jul 17, 2009
Sparko1
  • 167 Answers
SOURCE: hlp5063 no picture, have tested and replaced....
The Ballast voltage should 300 volts. You may have a problem on the power board. Possibly some bad capacitors. Look for the tops of the capacitors to be domed instead of flat.
Posted on Aug 01, 2009
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
My toshiba 52hm95 i still without a picture replaced the lamp and the ballast,the color wheel spins(cut the knob with the plastic tip attached from the lamp access door to get it to power up while firing...
did you change the bulb or the bulb with housing. 2.5 volt is start up volts. this is to check if the bulb is there or not. check that you have the bulb connected good you can test the bulb with a meter. on rear occations the bulb may not work even a new one.
Nov 14, 2012 | Toshiba 52HM95 52" HDTV Projection...
Toshiba TheaterWide 52HM94 HDIM Input
The 52HM94 is a somewhat older set--best guess is it is not compatable for this use.
Aug 29, 2012 | Toshiba TheaterWide 52HM94 52" Rear...
My Toshiba 62HM84 won't start. I replaced the bulb and it still won't start. I replaced the ballast and the most I got was 1 second of light then off. The TV tries to start but still won't. Any...
I HAD THE PROBLEM OF BULB NOT TURNING ON. SOME PEOPLE SUGGESTED TO GET THE BULB CHECKED WHICH WAS ALRIGHT, SOME SUGGESTED TO CHANGE THE BALLAST WHICH WAS SMART BUT THERE WAS NO WAY TO CHECK IT OTHER THAN PUTTING A NEW ONE AND TESTING IT. I CALLED THE TECHNICIAN AND HE CHANGED IT BUT STILL NO PICTURE AND SAME CODE OF BULB NOT WORKING. THEN HE CHECKED FUSE ON POWER SUPPLY RIGHT NEXT TO WIRES BRINGING POWER SUPPLY TO BALLAST BUT IT SEEMED OK. HE DECIDED TO CHANGE IT TO SEE IF THIS FIXES THE PROBLEM AND WE CHANGED IT. WE TURNED ON THE TV AND WALLAH. SUGGESTION IS TO CHECK EVERYTHING BEFORE SPENDING MONEY ON NEW BALLAST OR BULB. 2 CENTS OF ADVICE, IT IS SOMETIMES WORTH TO BRING SOMEBODY WHO KNOWS WHAT HE/SHE IS DOING.
Aug 22, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
Hlp5063 no picture, have tested and replaced....
Aug 01, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Toshiba 52HMX94 rear projection T.V., i've had it for 4 years, replacing bulb every year. I now have another new bulb, but when I turn on the T.V. i hear a buzzing noise from the rear, and then...
Your TV requires ballast power supply board that gives you buzzing noise when TV turns ON.
Ballast supply board is available in Part Store and replacement of that board requires expertise.
Jul 23, 2009 | Toshiba Televison & Video
Jul 17, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba HMX94 DLP I replaced the bulb after it crashed and now red and green light flashes no picture. Please help. I tried two new bulbs. Mark T
The problem most likely is with either the lamp ballast or the light engine. The lamp ballast is the part that provides voltage to the lamp unit and is usually not all that expensive a part. The repair cost from a service shop can be about $300 or more. If you are handy, you can replace it yourself. Check out www.thepartstore.com for the ballast.
Apr 11, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 52HM94 52" Rear Projection HDTV Logo
474 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
