Question about KitchenAid "KEMS378sss Combination Microwave Oven / 27"""
KEMS378sss combo oven microwave control panel does not display
Unit has power, both oven and microwave work, but display shows nothing - not even error codes. I reset power and reset control lock but still no display is showing. i hear faint beeps when I press buttons - much quieter than before. Any advice would be greatly appreciated!
MicrowaveSvc
  • 9098 Answers
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jun 11, 2009
  • 7 Answers
SOURCE: kitchenaid microwave hood combo KHMS155LSS
First, do not leave this machine plugged in until it is serviced. If this is a KHMS155LSS, there is a very high probability that you have a keypad short. This defect can cause the machine to start on its own at ANYTIME; while you are on vacation or at work or at night while you are sleeping etc. Contact Whirlpool Customer Service and ask for Safety Dept immediately. They will most likely send A&E (Sears) out to fix it. Although they will fix the problem, if the keypad fails again, the underlying logic self start defect is still present. You should be under warranty if it is above model. Please be polite, insistent, but polite. With KitchenAid's pathetic quality in recent years, their customer service reps get more then an earful. Also, please go to the Consumer Product Safety Commision website at www.cpsc.gov and post a Report Unsafe Products report. This will help get this model recalled before someone loses their home or life. I almost had a fire this past Monday, Labor Day, 9/7/09 when my machine self started at 3 AM with a package of bacon left in it to thaw at room temp for the morning. What a smokey mess. Chinese made garbage. Shame on Whirlpool. Long live Hobart!, please buy back KitchenAid and bring back the lost quality.
Posted on Sep 09, 2009
nikeananth
  • 267 Answers
SOURCE: Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Posted on Sep 23, 2009
Hi ..Our Microwave stopped working. It is a GE Microwave- Convection Oven in wall combo with control panels for both ovens shared. Convection oven works fine. Microwave has no power...it is dead. ...
There is often a fuse and a magnetron thermal fuse or thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find links to helpful exploded view diagrams and order parts here.
Dec 02, 2010 | GE JE1460 Microwave Oven
Display panel is all white, nothing showing. microwave was still operational using "easy minute" button for quick re-heating for a few weeks, however, now that has stopped working. lights on the unit...
This is a common problem. Your CPU / LSI / display unit needs to be repaired or the entire control unit needs to be replaced.
We regularly repair such display units for customers nationwide by mail for only $39.95 postpaid with a one-year guarantee.
Or you can order a new control unit (part number 101871
) here for $244.36 plus shipping.
Aug 05, 2010 | Dacor DMT2420 1200 Watts Microwave Oven
My JennAir M170 just quit working, nothing.........bought in 1998. Time for a new one? If so, how do I go about just getting the micro for the combo unit? Or do I have to buy an whole new combo unit?
I would at least have a service tech look at it. Here are the comon items to check most of the time when a microwave just quits. 1 the internal fuse. 2 the power diode 3 the large capacitor 4. door open / closed micro-switches 5 the magnetron. The least likely suspect is the control panel yet can also cause the problem. You should still be able to keep this unit in service cost effectively. Until I had it checked out I would not give up on it.
Jan 09, 2010 | Jenn-Air M170 Microwave Oven
No power with my microwave no clock no light nothing
Some units also have a thermal fuse in line. Usually above the oven cavity. Look at your wiring schematic and see if it shows one, test for continuity and replace if bad. Also check to see if your main power comes in through your door interlock switches. Test each one for continuity with the door open and closed and replace if bad. If this is not it, you probably have a bad control board and it is usually not worth repairing. With Microwave Ovens we want to make sure your are careful. Even with the power off you can get shocked by the capacitor. Never work on a microwave oven with the power on. Very Dangerous Good Luck, Appliance Specialists.
Jan 03, 2010 | LG Microwave Ovens
Micro 6654438991 power surge from pole, light works, panel dead
Sounds like you should get estimates and turn in on homeowners insurance. Power surges are very destructive and you have lost the control board at least and maybe some switches. Eric
Aug 08, 2009 | Whirlpool GH7145XF Microwave Oven
No door lights, vent fan or microwave
That's what I thought.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 14, 2008 | Whirlpool GH4155XP Microwave Oven
We have a kenmore oven/microwave combo. some foil paper was put into the microwave and started smoking. Nothing melted, just became discolored. however, the unit stopped working altogether. no lights,...
If the internal fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or possibly on top of the cavity / body of the oven.
If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a VIDEO on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Apr 12, 2008 | Microwave Ovens
GE Spacemeker Microwave Oven xl1800
The Control Panel is failing. The Control Panel consists of a Keypad, and a Control PC (Printed Citcuit) Board. You can replace it as a complete unit. Not Cheap!!
Good Luck!
Feb 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Reset Microwave after a Power Outage
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
Sep 11, 2006 | Goldstar MV-1526 Microwave Oven
KitchenAid "KEMS378sss Combination Microwave Oven / 27""" Logo
48 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
