Question about Frigidaire FTF2140FS Front Load Washer / Dryer
Frigidaire front load washer LTF2140FS2 stops after every cycle and the start light blinks
I have to manually start each cycle. I have checked for clogged drain hose, I have duct tapped the door to make sure it's not coming loose. What else could it be?
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Nicole, thank you for allowing me to assist you!
Typically, the Start light flashing indicates that the cycle has paused or the door is not securely latched. If the hose is not clogged and the door is closing properly, then more than likely your washer is experiencing a communication problem with the control board or wiring issue. At this point, I would strongly recommend contacting a professional to make the necessary repairs.
Best of luck!
Posted on Feb 11, 2014
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
SOURCE: I have Frigidaire Affinity washer that beeps and blinks "dr"
Actually don't buy a new door mechanism yet. There is a metal ring that holds the rubber tub to the rest of the washing machine. It has a spring at the bottom of that ring. Pull it down and you will be able to get the ring off. Carefully peel back the rubber tub on the right had side near the door latch. Reach in side and unplug the bottom connector for a few seconds and plug back up. (Do this all with the power on). Then put the rubber tub back around the frame and put the metal ring back on. This should solve your problem. I had the same issue not too long ago.
Posted on Sep 06, 2009
SOURCE: My Frigidaire front load washer won't start
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Posted on Oct 11, 2009
BIKER T
  • 909 Answers
SOURCE: My washer stops half way through the cycle and
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Posted on Jun 13, 2010
rabbitbrains
  • 575 Answers
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
Posted on Sep 27, 2011
Error code on ltf2140fs2
Hello friend, I appreciate your post!
From my understanding your front load washer LTF2140FS2 is beeping 9 times and then you have to unplug it and plug it back in. When the unit is beeping do you notice any additional lights on the panel coming on? This information would be helpful in assisting you with getting a proper explanation to your current problem. -Matt
Jul 19, 2014 | Frigidaire Washing Machines
Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
Aug 31, 2012 | Frigidaire FTF2140FS Front Load Washer 10...
I have a Frigidaire front loading washer LTF 2140FS2 that will not start. I press the Start button door locks, press again the Wash Cycle light comes on. Then after a few seconds all the cycle lights...
Hi
Press and HOLD the Start/Pause and Cancel buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Daniel
Sep 25, 2011 | Frigidaire Washing Machines
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Timer Stalling
I would check the water hoses for twisting, make sure the water faucets are turned on all the way, and check the filters at the washer end of the hoses to make sure they are clean. I would also check the drain system to make sure it is clean and the machine is draining well.
Jul 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Washer won't drain water
My will start to cycle and then it will cease to spin. No grinding, no off balance noise-no spinning=no draining of water from tub/basin. Unplugged it for a full 4 minutes. Plugged it back in. Checked to see if washer was level-it wasn't. Made adjustments to ensure washer was level-EUREKA! washer finished cycle no problem. BOO-HISS! Two loads later, same issue as the first time-washer won't spin. Checked to see if washer was still level-it is, new issue-error coed E20 and all lights blinking. ANY suggestions?
Jun 14, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire FTF2140FS Front Load Washer / Dryer Logo
104 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
