Question about Frigidaire FTF2140FS Front Load Washer / Dryer
Frigidaire front load washer LTF2140FS2 stops after every cycle and the start light blinks
I have to manual start each cycle as it keeps stopping. I have duct taped the door shut to make sure its not coming open, checked for clogs. What else should I do?
  • 641 Answers
SOURCE: Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Posted on Sep 08, 2007
SkinWill
  • 148 Answers
SOURCE: frigidaire washer starts to fill then stops
Check the water level fill sensor. Some used to be pneumatic tubes connected to a sensor. Your washer may have a different type of sensor. It seems like it fills ant gets to a point where it expects the fill sensor to trip but instead just stops. Also re check ALL connections to main drive motor.
Also verify your mains power can handle the draw of the rated wattage. When it goes to engage the main drive motor it may not have enough current from the mains and simply stops.
Also check that the connection to the tumbler drum is not frozen.
Posted on May 02, 2008
SOURCE: My Frigidaire front load washer won't start
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Posted on Oct 11, 2009
BIKER T
  • 909 Answers
SOURCE: My washer stops half way through the cycle and
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Posted on Jun 13, 2010
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
Error code on ltf2140fs2
Hello friend, I appreciate your post!
From my understanding your front load washer LTF2140FS2 is beeping 9 times and then you have to unplug it and plug it back in. When the unit is beeping do you notice any additional lights on the panel coming on? This information would be helpful in assisting you with getting a proper explanation to your current problem. -Matt
Jul 19, 2014 | Frigidaire Washing Machines
Good Afternoon Nicole, thank you for allowing me to assist you!
Typically, the Start light flashing indicates that the cycle has paused or the door is not securely latched. If the hose is not clogged and the door is closing properly, then more than likely your washer is experiencing a communication problem with the control board or wiring issue. At this point, I would strongly recommend contacting a professional to make the necessary repairs.
Best of luck!
Feb 09, 2014 | Frigidaire FTF2140FS Front Load Washer /...
WASHER TROUBLESHOOTING
My GE front loader keeps stopping in the middle of the cycle. It does it over and over and never completes the cycle. It just started doing this a couple of days ago. It took me all day to do one load of laundry the other day. Tried again today with no luck. I tried it on three different cycles and all the same. It just keeps stopping and going to pause. When I shut it off it takes about 20 minutes for the door to unlock. Is this problem worth fixing or should I junk it?
Aug 07, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire FTF2140FS Front Load Washer / Dryer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
