Question about Tecarta NKJV Addon
Will not load on my nook
I have 2 versions of the tecarta bible on my nook and they will not open. It tells me to fotce closed. I use them alot and miss them. Help please
I am running Vista. I have loaded an older version of Comptons Interactive Bible. It loaded, installed just fine,. I cannot view the videos. I get a view error. Can this be fixed?
First, make sure the software lists your OS (Operating System) as compatable. If Vista is not listed it may not ever work correctly or you may need to download a "patch" or driver to make the software function as designed. Next, you should contact the software manufacturer directly and see if they have a fix or patch for you specific problem. And lastly, it may be a problem with the software or drivers on your machine. Can you play other video software that is similar in nature? What is the year of release on the Comtons software?
Apr 07, 2011 | The Learning Company Comptons Interactive...
I inserted the disk in a new computer and a window opened telling me this software is not compatible with this version of windows. How can I use resource on this computer?
I'm afraid this version is only compatible with Windows versions 98/95/2000/Me.
It may be easier to consider downloading an alternative package, there are a number of good quality products freely available for download, for example:
http://www.theophilos.sk/
http://www.e-sword.net/downloads.html
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 20, 2010 | ValuSoft The Bible Library Suite Full...
Function button not working, cannot get bible to recognize numerals, thus cannot go to 1 corinthians 1 for example, it reads Q Corinthians Q
Remove the five screws from the back of the Bible, gently separate the front from the back of the Bible with a flat blade screwdriver. Note, when the Bible is apart be as careful as you have ever been in your life with the display and especially with the flat cable connected to the display, or you might accidentally cause a void line to permanently appear in the display when you get it back together. Gently remove the rubber keypad. Take a Q-tip swab or two with some rubbing alcohol and gently clean all of the black contacts on the back of the keypad and also where the contacts touch against the circuit board. Make sure that you clean every one of them leaving no specs of dust or cotton on anything. Also leave none on or near any part of the display or window or you will be looking at these for the next ten years while you read the powerful Word of God. This has worked for me several times, but I own three of them, and still have the first one I purchased new about twenty years ago. The Frankin KJB-640 is by far the best electronic Bible ever made and nothing has since come remotely close. KJB stands for King James Bible. Any other so called version belongs in the garbage can. Trust me on this one, and read the Bible daily, or continue being completely miserable for the rest of your life.
RC
Oct 01, 2010 | Franklin Electronic Holy Bible - King...
Which bible verse has ''humility before honor'' in it
Hi.
It is Proverbs 15:33 or 18:12, (Before Honor Goes Umility). You can grab a King James bible and read this very interesting passages at 15:33.
God bless you.
Ginko.
May 10, 2010 | Franklin Electronic Holy Bible -...
Is it possible to load Bible book (not audio) into my Ipod? How? I have in it loaded already an NIV audio Bible. I want the book to read for Bible study. Thank You.
Hello and thank you for using Fixya's services.
You need to make sure that the Ipod is compatible with the filetype in order to load and see correctly.
To do this, right click on one ofthe Bible files and choose properties. See if you can tell what file type it is. I believe that Ipods only support a handful of files types.
You can also check out this free software for adding video's to your Ipod, it will show you how to convert the files to a compatible version if need be.
http://www.splashdata.com/filemagic/
Hope this helps!
Nov 20, 2009 | Apple iPod classic MP3 Player
DOWNLOADING BIBLE
how 2 save energy of a battery cell of nokia 6300
Aug 05, 2008 | Nokia 6300 Cellular Phone
Tamil fonts for k 750i
I have installed tamil bible on k750i but it displays just boxes pls help me call om 9972252270 its very important
Mar 06, 2008 | Sony Ericsson K750i Cellular Phone
Tecarta NKJV Addon Logo
Top Tecarta Apps Experts
Brett Duxbury
Brett Duxbury
Are you a Tecarta App Expert? Answer questions, earn points and help others
