Question about Acer Computers & Internet
No display on screen in Acer aspire 5830TG with GeForce 540
Hello, I have an Acer Aspire 5830TG laptop with Nvidia GeForce 540 graphic card. Recently while working on the laptop, the display went off, all of a sudden. Now, I can't see anything on the laptop screen except a light brightness. However, when I use an external monitor using a VGA cable, I get the display on the external monitor. I took it a local technician. He tried replacing the LCD with one of his, but same problem. He visually checked the video cable, and said that it looks okay without any disconnection. Then he said that the problem might be with the graphic card as the display on the laptop screen is linked to graphic card, while the display to external monitor is not. So, somehow he checked the graphic card connections for any dry connections and checked the voltages at various points and told me that the graphic card is faulty and needs to be replaced. I am still not convinced with his diagnosis as I am still getting the display on external monitor and can still access the graphic card details and graphic settings on the computer and view the graphic card driver and update it as well. So I can't seem to believe that its the graphic card at fault. Can you please tell me that can the problem I am facing be caused by faulty graphic card at all? Should I believe the technician and go for graphic card replacement and spend so much? Thank you.
  • Vibhor Mathur
    Vibhor Mathur Feb 10, 2014
    So their shouldn't be any problem with the Nvidia graphic card?
  • Acer Master
  • 1,087 Answers
If it shows on an external monitor but not on the laptop screen, either the screen ribbon cable has come loose, the inverter/ccfl has died or the lcd screen has died.
If you boot your laptop to external monitor, then unplug the monitor - try shining a flashlight across the screen to see if you can see any dataNo display on screen in Acer aspire 5830TG with Ge - icon1.png/screen info - if you can, then the inverter/ccfl has died. If not, either the screen has died or the cable has come loose
Posted on Feb 09, 2014
Testimonial: "So their shouldn't be any problem with the Nvidia graphic card? Should I just double check the LCD, CCFL, Inverter and cable? Also, are the CCFL and inverter separate components on the lid or are they attached to the LCD panel?"
rebel_245
  • 24 Answers
SOURCE: acer LCD fault
You are correct about the inverter, on laptops about 9 out of 10 issues with video may be caused by the inverter, however before you replace the inverter try checking for new driver updates for your video, if this fails you may try hooking up an externail monitor and see if that works ok, if it does then i would try to have the inverter replaced.
Posted on Mar 29, 2007
Techvisitor
  • 63 Answers
SOURCE: graphics card for ACER ASPIRE 7720G laptop.
This is from Acer's US SUpport Site:
Video Subsystem
ATI Mobility Radeon™ HD 2300 with up to 896 MB of HyperMemory™ (128 MB of dedicated GDDR2 VRAM, up to 768 MB of shared system memory), supporting Microsoft® DirectX® 9 and PCI Express®
or:
ATI Mobility Radeon™ HD 2300 with up to 1 GB of HyperMemory™ (256 MB of dedicated GDDR2 VRAM, up to 768 MB of shared system memory), supporting Microsoft® DirectX® 9 and PCI Express®
(varies by model)
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=561&formid=3404&website=AcerPanAm.com/us&siteid=7293&words=all&keywords=&areaid=7
Posted on Oct 31, 2008
patemi
  • 366 Answers
SOURCE: how to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Posted on Jan 08, 2009
Dev_Null
  • 10 Answers
SOURCE: Acer Aspire 5000 laptop with SiS 760_M760 video driver
The Aspire 5000 actually has a 128mb video card. i am using one right now as a matter of fact. Reboot your acer. when you see the acer logo. press F2 once into the bios screen move to the next tab. High light the 64mb next to the video adaptor and high light 128mb.
Posted on Feb 06, 2009
romsky79
  • 822 Answers
SOURCE: Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
Posted on May 20, 2009
Graphic card for Acer aspire
One of the best ones is the ATi Mobility Radeon HD 3650. The best NVIDIA one there is the NVIDIA GeForce 8600M GT. But the ATi GPU is better.
You will probably need to get a new card fitted by Acer or a named specialist.
Mar 05, 2014 | Acer Aspire 7720-6794 Notebook
I agree with you, if the graphic card was bad, the external display would not work. He probably connected a non-compatible LCD. Unfortunately, replacing the LCD will cost about $100 plus labour. Is it worth it for a 6 year old laptop or should you just continue to use it ask a desktop.
Mar 01, 2017 | Acer Computers & Internet
Hi, i have acer aspire 4750G. It has 2 graphic cards, an intel HD and nvidia 540M.. currentIy its using the intel HD. I want to know how can I switch it to nvidia?
Heres how... Its normal to have 2(two) display adapters on Acer Aspire 4750G. To enable NVIDIA GeForce, install the Intel HD Family Chipset Driver First from the installation disk that is included on its package, or click here, or if link doesnt work find it here. Then install the NVIDIA GeForce Driver, also included in installation disk, or click here. That should fix it. Enjoy the 2GB NVIDIA GeForce GT 540M.
Apr 20, 2011 | Acer Computers & Internet
I need a driver for my acer aspire m1640
Download Acer Aspire M1640 Chipset & AHCI SATA Driver For Windows XP Description: Intel Chipset and AHCI SATA Controller for Win XP
Download: Chipset-and-AHCI.zip
Download Acer Aspire M1640 Audio Driver For Windows XP Description: Audio Driver for Win XP
Download: Audio.zip
Download Acer Aspire M1640 Network Driver For Windows XP Description: Wireless WLAN Wifi, Modem and Ethernet Lan Card Driver Package For Win XP
Download:Wireless-Modem-Lan.zip
Download Acer Aspire M1640 ATI Graphics Display Driver For Windows XP Description: ATI VGA Graphics Display Driver For Win XP
Download: Part1: ATI.rar.part1 Part2:ATI.rar.part2 (Download both parts and extract using winrar)
Download Acer Aspire M1640 Nvidia Graphics Display Driver For Windows XP Description: Nvidia Geforce 7050 VGA Graphics Display Driver For XP
Download: NVidia.zip
I hope this information will be helpful. Thank you for using FixYa!
Jan 09, 2011 | Computers & Internet
What kind of low profile graphics card can I put
Actually you must buy a graphics adapter cpi express compatible to (X1 and X16).
Nvidia GeForce 8200 graphics
PCI Express slots (X1 and X16).
NVIDIA® GeForce® 8200 on-board graphics and PCI Express® 2.0,
ok regards
uttam
Jan 07, 2010 | Acer Aspire X1200-B1601A PC Desktop
Graphics card for ACER ASPIRE 7720G laptop.
Video Subsystem
or:
(varies by model)
Oct 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
Problem with video card on Acer Aspire 5920G
Your computer has the next video card.
NVIDIA GeForce Go X8600M GT
You can try downloading the drivers from http://www.nvidia.com/Download/index.aspx?lang=en-us
make sure you select the product Type: GeForce
and Product Series: GeForce 8M (notebooks)
if not, search at ACER website
Dec 03, 2007 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
