Question about Tascam Cd-rw900sl Cd Recorder/player
How do I set the volume on the CD-RW900SL - Tascam Cd-rw900sl Cd Recorder/player
Teac cd-w224sl-50
tascam.com/content/downloads/.../23/CD-RW900SL_web.pdf
tascam-ca.com/product/cd-rw900sl
Jan 14, 2015 | Tascam CDRW-900SL Slot Load CD Rec w/ MP3...
After i record and play the cd on another player i have turn volume up
You probably need to adjust your recording volume on the recorder and not just copy the source as it is...
Mar 21, 2014 | Tascam Cd-rw900sl Cd Recorder/player
No vocals on recorded disc
You need to check your setup's recording volume and interface. You did not mention if you are trying to record from RCA or digital inputs.
It sounds like your recording level is not set up to catch all of the music. I'd love to buy a unit which cuts all of the whiney vocals from good trance music it is very hard to do with all of the layers of recording.
Feb 07, 2014 | Tascam Cd-rw900sl Cd Recorder/player
D- IN UNLOCK on my display and it wont let me record, how do i fix this?
This happen when you have the setting for Digital when the analog signals are input. It is telling you the sync signal expected by a digital input is not there. I have seen this many times and it is just a setting of input not a malfunction of the unit.
Jan 14, 2013 | Tascam Cd-rw900sl Cd Recorder/player
We can't get the volume loud enough to hear when we record to a CD
This unit is a pro unit that makes use of XLR type inputs. These are typically at +4 dBm signal level not that of the -10 from RCA type mixing boards. So what you need to do is take the RCA outputs from your source and hook them to a IHF or unbalanced to Balanced converter and they are available from MCM Electronics. This device here should take care of the problem.
http://www.mcmelectronics.com/product/555-8485
Oct 06, 2012 | Tascam Cd-rw900sl Cd Recorder/player
Tascam CD-RW900sl manual in spanish
I think the manual is in Spanish as well when I saw one last. Look further on in the book.
May 15, 2012 | Tascam Cd-rw900sl Cd Recorder/player
Tas cd-rw 900 when recording in church services, it skips tracks. sometimes it only records for a few seconds and starts over.
If A.Track is on it will interpret silence (or near silence that meets user thresholds) as a new track. Disable A.Track with the Jog Dial when setting up to record.
http://audio.manualsonline.com/manuals/mfg/tascam/cdrw900sl.html
Page 26 under Automatic Track Division...
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/55030670_PM_EN.pdf
Jan 28, 2011 | Tascam Cd-rw900sl Cd Recorder/player
Tascam Cd-rw900sl Cd Recorder/player Logo
48 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
