Question about Hilti Dg 150 Diamond Grinding System With Dpc 20 Nice
Cooling fan broken cooling fan on hilti dg 150, need spare part
The fan for the te22 drill
hi
I very much doubt if you can get one as the fan ( plastic )
is bonded to the rotor spindle
Dec 07, 2016 | Hilti Drills
Hammer drill hilti TE 10 . Hammering parts broken. Replacement require.
Check the attached links, Contact Hilti and order parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovative Solutions for Construction Professionals Hilti Canada
Results for My preferred Hilti Centers
HILTI AUTHORIZED DISTRIBUTOR AND RENTAL LOCATIONS
Hilti Tool Repair Hilti Canada
Mar 10, 2016 | Hilti Drills
Need a cooling fan for hilti hammer drill te22
Claudette,
From my experience with Hilti tools, you have to send the tool back to them for repair. I have not had much luck in getting any parts from them. Sorry!
May 07, 2015 | Hilti Drills
Hilti dg 150 stops under load
This sounds as though there is a short in a wire inside after the on / off switch. If there is a burning smell when this happens then there is likely to be a short cause by normal wear from debri getting inside housing / casing.
Apr 27, 2012 | Drills
Replacing brushes on a hilti te 7a 36v cordless hammerdrill
the fan probably exploded and you would need to replace the motor assembly. You can contact HILTI direct at 1-800-879-8000 for parts and breakdowns.
Jan 26, 2012 | Hilti Drills
Cooling fan broken spares?
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
The cooling fan solution in this case needs to be replaced with an after market Graphics Card cooler. One that fits this GeForce 9400GT.
That's the heatsink and the fan!
Thanking you kindly
damnor01
Feb 10, 2011 | Nvidia Microsystems GeForce 9400 GT, PCI...
Need locations in europe and asia for spares outlet and price for armature assy for hilti TE 2s drill - ( due to short in windings and comutator) purchased on 1981 from saudi arabia -
Go to Hilti's website and choose your country. You can find locations and parts. The TE2s was not introduced until the early 2000's. In 1981 a drill that size would have been a TE12s. If that is your model parts are no longer available through Hilti.
Dec 25, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
I own a Hilti SF 150-A 15.6 volt cordless drill ( non hammer type ). I need a trigger assembly for it. Where can I order one?
As i know Hilti has a free of charge repair or replacement of defective parts; Hilti tools are covered by a lifetime manufacturer's warranty against material or manufacturing.Call them direct at 1-800-879-8000, the only place I know to get parts from is Hilti.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 18, 2010 | Hilti Cordless Drill Driver SF 151A 20Ah...
Gear grease for hilti drill/driver
The genuine hilti grease isnt that easy to get. but I have used a stadard lithium grease in the past without any problems.
Feb 09, 2009 | Hilti 3431126 SF 144-A CPC Drill/Driver
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
Hilti Dg 150 Diamond Grinding System With Dpc 20 Nice Logo
Top Hilti Saws Experts
Tom Chichester
ray gallant
Are you a Hilti Saw Expert? Answer questions, earn points and help others
