Question about GE Dryers
Wiring diagram for m460-g timer
Need the wiring diagram for a dryer timer m460-g part number 212d1233p004
4 Suggested Answers
ned_san_jose
  • 234 Answers
SOURCE: i need a timer for the M460/g kenmore elete dryer
repairclinic.com has the best selection of timers. imo
Posted on Sep 18, 2009
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Fix-Fox
  • 7 Answers
Here you go again :-)
Old whirlpool thin/twin Dryer timer old timer M404-G New timer M460-G how to hook up
The problem as stated is that the new M460-G timer does not have the same pins as the old one (because there seem to be a variety of sub-models under the M460-G name). However, I have successfully (at least to provide the timed heat function) used a different M460-G on my Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, I had to figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also by inspection of a wiring diagram at appliance pros dot com
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
c / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)48146720-bbc3-47da-833c-6d50a0cf5df0.jpg
Sep 06, 2015 | Whirlpool Dryers
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
Need to know which color wire goes to which connector on the timer. frigidaire wiring diagrams
Hi garyab9ss, I appreciate your post!
It appears your inquiry is listed under Frigidaire Electric dryer and you need the wiring diagram. May I have the model number please? You can typically locate the serial tag (which lists your model number) on the upper front, as you open the door or on the right/left edge on the inside of the door. Also, please provide me the timer part number that you have in hand. With this information I can deliver the correct material to you. Thank you! - Z
Jul 28, 2014 | Frigidaire Electric Dryer
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
A / Gas / Org
C / Motor / Wh
BK / Motor / Wh
R / Gas / Org
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Nov 19, 2013 | Whirlpool Dryers
M460-g timer wiring diagram
You will never get a diagram for that. The M460 was used in thousands of machines, did you pull the bone-headed move of removing the timer leads without marking them? Post the actual model number of the machine and I can find the diagram for that model and work off of that... Help Me Find My Model Number RepairClinic com
Aug 18, 2012 | Maytag Dryers
Hello, My GE Dryer, Model M460-G timer won't shut off
Sounds like you have a faulty timer switch, check with your local supply house and get the same type of switch.
When you go to replace the timer switch, unplug the dryer, then remove one wire at a time. This will prevent wiring mix-ups.
Good luck,
I hope this helps
Oct 11, 2009 | GE Dryers
I need a timer for the M460/g kenmore elete dryer the number on timer is o14-96648
Sep 17, 2009 | Kenmore Dryers
Dryers Logo
81 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
