Question about Malber WD1000 Front Load Washer/Dryer
Can you use the dryer cycle ONLY without using the wash cycle first?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Yes
Posted on Feb 10, 2014
Electric dyer stops mid cycle Whirlpool
It could be the lint screen needs cleaning, and not just removal of lint, but washing with warm water and a soft brush to remove fabric softener / static cling sheets that can build up and without being obvious, clog the screen. If there is not adequate air flow and the dryer is over heating it may shut itself off as a safety precaution.
Also, i'm not sure about this model, but many dryers have moisture sensors. These can become ineffective do to fabric softener sheets build up that coats the sensors. Check the owners manual and locate the sensor. It is just two metal contacts inside the dryer. Clean them with warm water and a nylon scrub pad, like you would use to wash dishes, but not steel wool or anything too abrasive.
Apr 12, 2014 | Dryers
Model #110.88752793. Not sure of age as it came with mobile home. I have used it daily for 1 1/2 years. Dryer works extremely well and washer did also until last night. Two washes with the same problem. On...
Run the washer without a load in it. Open the lid when it goes to agitate and see if it is actually agitating by hold the lid switch down
with a small screwdriver or a pen. You may hear the grinding noise while it's agitating, just not as pronounced. You most likely just need the "motor coupling" on the unit.
Post back your results.
Sep 26, 2011 | Kenmore 88752 Top Load Stacked Washer /...
My dryer leaves the clothing semi damped rather than completely dry like it used to. So now we have to run the cycle twice to obtain the results we want.
Greetings,
here is a quick way to see if its your dryer or vent...disconnect the vent from behind dryer and let blow without being hooked up. Now, wash some clothes and using caution not to overload the dryer and check it again after a normal dry cycle. if ok , the vent is blocked somewhere from dryer to outside vent. if still not working with vent disconnected. There is a problem with dryer...you will most likely find a blocked vent.....Bruce Denton...if I'm correct, please advise if your satisfied...thank you
Jan 05, 2011 | Whirlpool Dryers
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Dryer Problem
EC4 The temperature of air vent
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
Nov 21, 2008 | Haier HWD1000
Wash cycle moves to drain whatever the setting
Float switch in bottom of machine activated (leak) or pressure switch (or bottle for pressure switch) blocked or faulty.
Jul 10, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washer does not drain water
You have a sock in the pump. If no noise in spin you have a bad lid switch.
Mar 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
