Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Maytag PAV2300 AWW nevre agitates and only spins once.
My 4 year old Maytag PAV 2300 AWW never agitates, but will spin sometimes, (one cycle only) then needs to wait 45 minutes to spin again.  I have taken it apart and the trasmission's spindle's teeth looks fine and the bottom plastic agitator's teeth look fine as well.
I ran a cycle, with a small load of water, without all of the plastic agitator parts to watch if the metal spindle turned, which I am assuming is the top part of the transmission, and it did not turn.  The spin cycle runs (ocassionally) with clothes and water in it, but never the agitator.  The machine is running though and all of the water cycles adding water and draining normally on time.
I think the spin cycle running after waiting 45 minutes is especially strange.  I don't know how that relates to the agitator never working????How can I tell if it is the transmission or the timer?  Or could anything else be the problem and how can I diagnose it?
I really appreciate your expertise and my wife would really appreciate me fixing this thing,
Brian Sawyer
Denver, Co.
  • 1 more comment
  • brian s Oct 26, 2007
    Also, I have checked the belt and cleaned all of the pulleys.  I also checked the lid switch and there is no debris between the tubs.
    Brian
  • brian s Oct 30, 2007
    Thank you for the response.  I not sure if that is the problem because it does spin on the first cycle and that is after the agitation mode.  The agitation mode never works, even when cold, during the first cycle.
    If you will permit me, this is a list of the problems on each cycle, chronicologically;
    1. Fill, seems ok, fills with water normally.
    2. No agitation,  the belt & all pulleys turn clockwise, but the spindle above doesn't turn and the tub won't turn manually either.  ( strange thing is that in-between the two tubs you can see that there are water bubbles that move counter-clockwise....... maybe that is normal?????)
    3. Drains, after a quick click, it seems to drain normally
    4. Spin, the first time this actually works, the belt and all pulleys turn counter-clockwise and it spins fine.
    5. Rinse,  it fills the tub with water, then immediatly goes to -
    6. No agitation,  again belt and all pulleys turn clockwise, but no turn of the top spindle, (again, the small bubbles move counterclockwise.)
    7. Drains,  again a click, then drains normally
    8. Spin,  this time it does not spin.  The belt and all pulleys turn counter-clockwise, but the tub does not move..... ( just like the aggitation mode )
    Some quick notes;
    I took off the water pump and all was clear and working fine.
    The belt seems fine, ( a little loose, but fine) except 2 very small cracks.
    If trying to repeat process soon, spin doesn't work either time, untill 45 minutes or so.
    All spindle teeth seem fine.(the greasy metal spindle never turns)
    When cool, it will spin in any spin cycle as I move the dial and jump around manually
    It does the same thing every time I have tested it, maybe 15 different times.
    Maybe it is the bearings somewhere and when they overheat, it shuts down the bottom part of the transmission, while the top part of the transmission is stripped out permanently??
    Can I fix this, or do I need to buy a new washer?
    Thank you again,
    Brian
    I am sorry, after reading your response again, I that it was a little over my head, yet maybe on the money.  Are you saying that,
    The motor is two directional and 1 direction (spins the transmission) doesn't work at all, the other direction (spins the tub) is overheating and tripping the thermal trip.
    Please forgive my ignorance about motors, it just now hit me.
    Is it possible that the motor would have 2 problems like that?
    Any way to check the difference between the motor and the transmission having the problem?
    Thank you for your patience,
    Brian
  • 64 Answers
Ive never seen a Maytag washer, but I think know the principle. So! I think the motor turns in one direction to wash & the opposite direction to spin. Now, if the transmission is very stiff in the 'wash mode', that could be why its not washing. The motor could be overheating & the thermal trip in the motor cutting off the electricity supply hence having to wait 45 mins for it to cool.
Not too sure! However I think I am on the right track. Let me know please
Posted on Oct 26, 2007
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
How to replace timer knob on Maytag PAV 2300 aww, old one snapped off leaving just the stem
This is from another site but does a good job of explaining how to change your timer:
http://www.the-appliance-clinic.com/myttimer.html
The hardest part will be swapping the knob because you have to lift the top of it off and sometimes they can be fiesty.
WORDS OF CAUTION.
DO NOT pull all the wires off of the OLD timer. DO a ONE for ONE wire swap. i.e pull one wire from the old timer... and hook it up to the new one on the exact same terminal as the old timer.
Kelly
Mar 22, 2011 | Maytag PAV2300 Top Load Washer
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Excess water in clothes at end of spin cycle
SOUNDS LIKE THE MOTOR COUPLING TO ME.
May 15, 2009 | Maytag Washing Machines
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Oct 27, 2007 | Maytag PAV2300 Top Load Washer
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
223 people viewed this question
Dan Webster
Dan Webster
Sal De
