Question about Duravit Home
SensoWash nozzle blocking
The nozzle stopped working. it starts to go out but jams partway. I tried unpluging the unit and test manually to extract the nozzle to see if there is any thing blocking it and nothing hinders the movement. Any advise?
  • 121 Answers
SOURCE: paper jam
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Posted on Oct 27, 2007
  • 390 Answers
SOURCE: PAPER JAM
Hi, oh dear, you have a paper jam in or near the roller or very small one in carriage. Open up unit as if rplacing cartridges, get a torch if you have to and search for tiny jam. A good clue, is does the carriage return to correct positon upon opening?
Posted on Feb 10, 2008
quang123
  • 107 Answers
SOURCE: sony DCR-TRV510 error code C 31:10 tape bay closes then opens
The error code was indicated the LS chassis assy is defective, bad luck it require a qualified Tech trained from Sony. I suggest you to bring it in Sony to repair it would cost you about from $180 to $250 if you are in AUS
I hope that give you some ideas
Posted on Dec 04, 2008
  • 1121 Answers
SOURCE: scanner stops partway along path, motor whines
is a scanner , with a dirty/scratch mecanical gear problem. send to local repair center
Posted on Oct 30, 2009
pineworks
  • 4041 Answers
SOURCE: I'm getting the error code 5100:
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
Testimonial: "My printer is up and running once again, thanks so much!"
Karcher troubleshooting
check your lance nozzle is not blocked... Remove the lance from the trigger assy and see if you have water coming through then. If you do then the nozzle is blocked :@)
Jul 21, 2014 | Karcher K2.26 Electric Power Washer
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
My Brothers Itellifax 2820 says there is a "document jam" and that I should clear the scanner then press the stop key. There is not paper jam whatsoever and I can't fins any other problem. However, I'm...
open the top of the unit and clean all rollers and test all of the "flap" switches to make sure that they are resetting as they should, if that doesnt work unplug printer for 10 mins then plug back in allow it do turn on and do its self test them try again
Jan 01, 2010 | Office Equipment & Supplies
Is saying clear paper jam when no paper is jammed , i have tried switching everything off and back on but still comes back, have checked all around for jammed paper but cant find!
Try this:
Unplug the printer from the wall and wait for about 5 minutes before plugging back in. This may be sufficient to cause a "hard" reset of the unit (turning the unit off and back on from the front panel switch is a "soft" reset as the circuit boards still have power to them.)
If that does not work, unplug again and look closely in the printer's paper path. There may be a small shred of paper hung that is blocking a sensor unit.
Nov 19, 2009 | Lexmark Office Equipment & Supplies
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Power washer problem no pump action
sounds like nozzle is blocked.small bits of grit jam nozzle unscrew and make sure its clear turn water on and pull trigger to see if gun trigger works,then refit nozzle check again for spray.if clear start up and try out.if no go then pump probably needs cleaning and relubing seals.
Apr 20, 2009 | Comet Garden
Selphy 720 !st card pass.card stopped partway by power lead-carelessly placed.no paper jam.But display now permanently shows paper jam symbol- not cleared by off/on. no function from any button. ...
Start first unplugging power for ten minutes, and see if it clears the error.
If it does not inspect the printer for paper or foreign objects, take out cartridge and put it back, see if this helps.
Oct 02, 2008 | Televison & Video
Piece of paper 1 inch by 2 inches jammmed and won't eject when I touch start button. I can't even see it with the cover open.
you have to open up your printer covers to extract that jammed paper. However, if you haven't tried tinkering with anything electronic before you will have to seek technical assistance from a qualified expert, but if you're willing and determined to extract that piece of paper, i suggest first you unplug any power connection from your printer, then unscrew the visible screws of the cover which is nearest the jammed piece of paper. never turn any cylinder if it resists your effort, however, try to manually turn cylinders where that small piece of paper is wedged until it comes off. Try to pull down on that piece of paper using a hair puller or forcep.
Apr 01, 2008 | Computers & Internet
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Home Logo
73 people viewed this question
Top Duravit Home Experts
Craig Butler
Craig Butler
Paul Carew
Lawrence Oravetz
Are you a Duravit Home Expert? Answer questions, earn points and help others
