Question about Microwave Ovens
Sharp Carousel Microwave Convection R9-H66
While using the convection option the oven shuts down during pre-heat after about 5 minutes. It will immediately start back up when you push start button. The digital display doesn't go away during pre-heat or if you use time, convection, start. But in either situation it stops after about 5 minutes. The fan doesn't come on to cool the oven down. The fan does work during the heating period.
2 Suggested Answers
fathitkf
  • 1871 Answers
SOURCE: sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Posted on Jun 03, 2010
I have a R-9H83 Sharp Carousel II Microwave Convection Oven that I have had for years and now when I use the convection to bake, it only will stay on for a few minutes and then just shut down. Any...
If you use a sensor function, the sensor may be obstructed, please clean the sides and top of your microwave with a dishcloth, warm water, and soap to dislodge any rough or stained spots.
If setting a timer, when setting to bake please pay close attention to the unit of measure so that you set it right, minutes vs. hours as you may leave the oven to do its business and return without noticing it did exactly what you told it to do but you had thought you entered a longer time.
Nov 21, 2013 | Sharp Microwave Ovens
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
I have a sharp carousel but the convection oven is not heating up. The microwave works.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';
May 24, 2011 | Sharp Carousel R530EST Microwave Oven
It is a sharp R-1870 turns on and runs but no heat from convection or microwave also carousel does not turn
heatman101
Apr 09, 2011 | Sharp R-1870 Convection/Microwave Oven
Sharp carousel convection/grill/microwave maybe R990
Hello :
WARNING :
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
