Question about Refrigerators
Whirlpool gold gb22dk
I noticed the refrigerator wasn't running and the inside temp was at 50 deg. I turned the timer knob and it started. The marked the timer knob and it is moving now and the refrigerator is working. Don't trust it though. Would you suggest a new timer or something else?
  • Ron Hopfner
    Ron Hopfner Feb 09, 2014
    Typo... what I meant to say is that I marked the red timer knob to see it's turning through the cycles. It is. So now the refrigerator is working and I'll wait to see if it stops again. I seems like the timer was stuck, but I'm wondering if there is something that controls the timer.
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Some models have a timer that runs when the defrost thermostat closes. You could have caught the refrigerator in a defrost cycle. Watch the timer. If you do decide to replace it make sure it is wired correctly. The replacement timer will most likely have a "flying" lead that must me installed correctly to the right terminal or it will not advance as it is designed.
Posted on Feb 14, 2014
Testimonial: "Thanks for the advice Ty but it turned out to be the temperature control. I don't know why I could get the refrigerator to start by turning the timer knob, but what I found was that if I just tap slightly on the temperature control while the refrigerator was "hung up" and not starting, that it would start right up. There's a relay on the temperature control that's part of the assembly. I suppose when the thermocouple calls for start the relay is engaged, but the relay evidently has some bad contacts. I replaced the temperature control assembly and all is well. Thanks again!"
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Posted on Sep 06, 2009
  • 1218 Answers
SOURCE: Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Posted on Nov 25, 2009
FRT211NLHWO FREEZER 22 DEG FRIDG 50 DEG
Lets begin by placing defrost timer into forced defrost. The defrost timer is inside the fresh food compartment and behind the control panel above the top shelf. Click Here=> 215846602 Defrost Timer
sea_breeze_274.jpg Try turning the timer clockwise slowly until you hear compressor and fans stop. Allow to remain here for 30 minutes. The timer if good should come out of defrost itself but if not it is a clear indication that the timer be replaced. You also should hear a crackling or sizzle coming from the freezer with door open. Also water should drain down to a condenstate tray below refrigerator into a tray that compressor fan warms to return back into air inside your home. If not timer causing the ice blocking airflow then we have the defrost heater and defrost thermostat to examine. They are located behind the rear panel inside freezer The=> 5317842502 Defrost Heater
And also the Defrost Thermostat=> 216872200 Defrost Thermostat
sea_breeze_276.jpg Testing the defrost heater can be found here=> 5317842502 defrost Heater Testing
I have laid these parts out as the timer being the most likely reason for warm temps in fresh food and freezer. If you have any questions I will be here to answer them for you, If helpful please rate, Thank You, Sea Breeze
Oct 30, 2011 | Refrigerators
Our Whirlpool Gold GB22DK model is not working...the freezer works fine, but the refrigerator is warm and not working. What part would I need?
check the thermostat is working by turning the tem down it should drop the tem if its dont change the thermostat
Aug 22, 2010 | Whirlpool Refrigerators
Refrigerator side light is out, but the compressor sounds like it's still running, plus the food is still cold. Interesting, when I turn the control knob to off, the light comes back on, but the compressor...
have never seen a ref of this style with a control board I would say you have some sort of wireing short. if the control is turned off the lights will still stay on, but they also should be on when if running
Apr 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side is thawing out and won't stay cold
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Oct 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Model ED20PKXAN01 side by side. Defrost timer
The timer could be set for accumulative instead of continuous . The one wire on the timer , set on the wrong terminal .
Jul 20, 2009 | Whirlpool Refrigerators
Works fine, but every couple of days I will notice that it will not be cooling, as the fan or compressor will not be working. I will turn the temp controler off, then back on and the compressor and fa
Check the condenser coil to make sure it is free of any dust, which will cause the compressor to overheat. The fan underneath may still be running, but until the compressor cools down it will not start.
If the unit always immediately begins running when you turn the control off and back on, then it may be you have a bad control. Have a servixe tech look at it, as you cannot repair the control...it's a throw away device.
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a GE side by side.. When we got home last night I noticed some water on the the floor and the power was on inside the refrigerator but the cooling apparently stopped working. I moved the fridge and...
The defrost timer will turn off the compressor and its cooling fan. At the same time it turns on the defrost heater, and usually leaves the freezer fan running. Defrost can take half an hour, easy. As soon as the defrost thermostat is satisfied, the defrost heater is supposed to turn off, and the compressor may come back on. The defrost timer is about the size of a cell phone, with about five wires going to it in a plug. It has a small dial on it that only goes one way. You can mark it and wait a half hour to see if it moves.
Apr 14, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
