Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi VS50705 i have the same problem (powers up, slight soft click-on sound, no picture or sound, timer light on) i looked at all the capacitors and they seem to be normal. i had a repairman out and he said that it couldn't be repaired because the power board was bad. he said the three tubes were getting power and was able to get the screen to light up with colors. all i want is some technician who will look into the component problem and repair it.
  • 1 more comment
  • Anonymous Aug 18, 2008
    TV comes on and on the creen is red with horizontal lines andthen in a few sconds the TV shuts off
  • m23s Aug 23, 2008
    My TV went dead. When pressing the power button, TV makes a click sound as if turning on then another click as if it just got turned off. Can anyone help.
  • Anonymous Apr 30, 2009
    where can you get the mirror for inside the TV?
    President:
  • 4,402 Answers
Send the board in to ptscorp.com
Posted on Feb 19, 2008
Flashing timer light on a mitsubishi wd-57733
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-57733 57" HDTV
Mitsubishi wd 62527 blinking status light what can I look at? No Picture, Flahing TImer light goes off agter 2 min then tv turns off and if you power it on it flases Lamp and Status multiple times?
This is a common issue with bad capacitors in the TV. You can call in a shop or repair it yourself. You can google the parts using this number Z1234TV
Mar 31, 2012 | Mitsubishi Televison & Video
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Blinking timer light and cannot turn on
How many times does the LED blink? Does it blink 6 times, pauses, and repeats? Or is it some other number of blinks? Or does it just blink continuously, once a second? (Note: on Mitsubishi's it is normal for the TV to blink rapidly for about 90 seconds after you plug the TV in, while the TV runs internal self-tests.) If the LED continues to blink continuously after 90 seconds, then the problem is on the DM board. There are 4 electrolytic capacitors, grouped together. I believe they are either 820 uF (mfd - microfarads) or 1000 uF at 16 Volts. If you check them, you will see that their tops are swollen (slightly rounded; not flat across). They will check okay with a capacitance meter or ESR meter, but don't believe your meter! Replace those 4 capacitors with either 820 or 1000 uF capacitors rated at either 16 or 25 volts. Make sure you use good, high-temperature (105 deg C) low-ESR capacitors. I recommend the "FM Series" capacitors from Digi-Key corporation, part number P12366-ND or P12379-ND. Less than $1.00 apiece. Good luck!
Dec 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Crackling noise on wd-65733.Timer light flashes.
put back your board its a cold solder from CRT socket board and the main board. if not check your tuner.
May 06, 2009 | Mitsubishi WD-65733 65" HDTV
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525
Sounds like the Capacitors on the PWB PCB You can get a repair Kit to fix that its called V26 PWB PCB kit at the following link. It contains the different capacitors and a CD with the info on the repair. Heres the link.
http://servicemanuals.vstore.ca/
Jun 28, 2008 | Mitsubishi Televison & Video
Tv shuts off
You could have a problem in the sweep or main power supply, Bad capacitors on the DM module, they will be all grouped together and have swollen tops, Coolent fluid leaking out of one of the CRT's. If you have no electronic or solid state repair experience, please get a pro to assist you in this repair. Good Luck
Apr 03, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
203 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
