Question about Crosley CW5000 Front Load Washer
Crosley front load washer only works on delicate cycle
I just moved into an apartment with a Crosley front load washer and I realized that it does not work on any cycle except for delicate cycle, if you turn the dial to any other cycle from delicate it does not work at all please help. Is this something that is fixable and if not what should I do? thank you in advance
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Most likely have a control prblem
Posted on Jun 10, 2014
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
  • 105 Answers
SOURCE: Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Posted on Mar 16, 2008
  • 198 Answers
SOURCE: crosley digital front load washer
jus try to lubricate the lock n then try.... it wil work
Posted on Jun 17, 2008
  • 47 Answers
SOURCE: Washer did not spin
JERRY,
IT SOUNDS LIKE YOU GOT TAKEN ON THIS WASHER. A NEW WASHER NORMALY WORKS, BUT IN SOME INSTANCES, LIKE YOUR CASE, IT COULD BE THE BELT OR THE MOTOR COUPLING. WHAT I WOULD DO IS CALL THE PLACE WHERE YOU GOT YOUR WASHER FROM AND HAVE THEM TO BRING YOU A NEW REPLACEMENT. THERE HAVE BEEN COMPLAINTS ABOUT WASHING MACHINES NOT WORKING RIGHT WHEN THEY WERE NEW. I HOPE THIS HELPS YOU AND ANYBODY ELSE WHO READS THIS WEBSIT, BECAUSE THERE IS NO SENSE IN THE STORE SELLING A BRAND NEW WASHER WHEN IT ALREADY LEAKS.
RODNEY
Posted on May 14, 2009
SOURCE: CROSLEY CAH4205AWJ FRONT LOADER WASHER
I know it's been a while since you posted this, but I thought I'd put an "answer" in here in case someone else stumbles across this post when trying to figure out what is wrong with their washer.
I'm not sure how to put it in service mode, but the problem is likely with your water pump. This pump pulls all of the water out of your machine before it goes into spin mode. If the pump doesn't engage then the washer won't spin. You likely need a new pump. They usually cost around $50 and are pretty easy to install. But if you have standing water in your machine, then you are going to have a mess when you pull the hose off to disconnect the pump. I'd suggest having a shop vac handy to **** up all the water as it comes pouring out of the Tub to Pump Hose. A towel isn't going to cut it. You're going to have lots of water that you don't want all over your floor.
Posted on May 29, 2010
Model - CFW4700LWO SERIAL- 4C31001977 crosley front load washer will not work in heavy load cycle. Times out after 3 mins and shuts off. Washer only works on casual cycle
This would be a control board issue, pull the panel apart and check for burned connector and circuit board overheating. If the control boards are showing signs of heat damage you may have a defective drive motor as well.
Mar 28, 2017 | Crosley Washing Machines
I HAVE A CROSLEY FRONT LOAD WASHER AND THE DOOR WONT UNLOCK, I HAVE TOWELS INSIDE, HAVE TRIED RUNNING ANOTHER CYCLE, PLEASE HELP
I have had that happen a couple of times and by hitting the pause or cancel button a couple of times it then opened.
Mar 05, 2014 | Crosley CW6000 Front Load Washer
Crosley digital front load washer error code lr
Does it beep or flash any other lights? What was the cycle or setting it was in when this appeared?
Aug 10, 2012 | Crosley CW5000 Front Load Washer
Affinity washer wont work on a normal cycle only delicate
looks like the windings on motor are burnt out , motor has different winding for different cycles
Mar 20, 2012 | Frigidaire Affinity ATF7000E Front Load...
Explanation of Wash Cycles
Sorry but you only have the one speed on this particular brand. Perm and short are just less time. The best thing to do is always use large water setting and less delicates in the load on a short cycle to compensate for the speed and protect your delicate fabrics.
Jan 27, 2010 | Whirlpool ET8CHEXSQ Dryer
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Leaks on Delicate but not on Normal.
Appears to have been the drain holes below the rubber drum flange. My wife cleaned in there for the first time after our speaking to a lowes sales person who owns one as well. When I monitored the next "delicate" load with the front panel off and after cleaning, there was no sign of water anywhere. Hope this was the solution. My wife also mentioned the loads (on delicate) came out damper than the norm but this time it was much drier. Wonder if delicate cycle may fill the washer higher than the normal cycle.
As a footnote we mentioned an occasional musty smell would occur and the same sales person said to not only leave the front door ajar but also open the soap drawer. When I checked the service manual I noticed the unit has a vent hose which vents into the soap drawer. All makes sense when you consider a front load is much tighter sealed than a top load.
Jun 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
Crosley CW5000 Front Load Washer Logo
120 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
