Question about GE JGSP23 Gas Kitchen Range
For GE GSP23 only bake does not work. Display shows bake,on,100F, but heat is not coming. No temperature change on display window.
SOURCE: GE OVEN DOES NOT WORK PROPERLY JBP69SGH2SS
I am not an expert, but this has happened to me. Examine your circuit breaker and see that it provides the amps that your oven requires. If it just barely provides it, then it could be that your circuit breaker is tripping if you have anything else on that line and it is being used. Especially hair dryers. If your circuit breaker is not tripping, you should contact GE or repair service because you may have a "power module" problem. Good luck.
Posted on Aug 24, 2007
SOURCE: GE XL44 Oven Temperature Issue
Have you tried replacing the bake ignitor yet?
Posted on Dec 17, 2007
aborcass
  • 2651 Answers
SOURCE: temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Posted on Oct 07, 2008
fixyourboard
  • 310 Answers
SOURCE: ge xl44 stove digital display clock stop working.
We see this failure due to two possible problems with the electronic control. Sometimes there is a failure that causes the display to shut off. Other times the display itself goes bad. The first case we can repair. If you send us the board we can check it out. If it is not repairable there is no charge. - www.fixyourboard.com.
Posted on Sep 30, 2009
SOURCE: GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Posted on Feb 28, 2010
Oven 388-610 won't heat up past 100F.
Hello. I'm not familiar with your particular unit but if it operates like most other brands, the display doesn't show temps under 100 degrees. From what you're describing, the oven isn't heating at all. I would suspect either a defective bake element or, an open thermostat which cuts the electricity to the elements if the temperature gets too high. If the safety thermostat checks good, then the problem most likely is the main oven control board--which simply activates a relay to turn on the element.
Nov 06, 2015 | Gaggenau Ovens
GE Model J S968S0F4SS. During bake display goes bake, oven turns off.
Oven Does Not Heat, But The Burners Heat - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
Range - Oven Does Not Heat, But The Burners Heat. To minimize the ... Turn yourrange OFF and either remove the fuses or turn the breaker OFF. Then unplug ...
How To Fix Oven With Little or No Heat When Baking ...
Troubleshooting Why Your Oven Won't Heat ' PartSelect ...
? 2:54
https://www.youtube.com/watch?v=ketJHf3rrSk
Sep 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your oven may not be heatingproperly. ... Neither the bake or broil elements ..
Oct 31, 2015 | GE Kitchen Ranges
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
Oven temperature is inaccurate and takes a long time to heat to proper temp. I have replaced thermostat with no improvement.
To Adjust the Thermostat
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 12, 2011 | GE J2S968SHSS Dual Fuel (Electric and Gas)...
My GE XL44 Self-Cleaning Gas oven heats up but is about 125-130 degrees cooler than what it is set for.
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a whirlpool range. During preheating the
sounds like you may have a bad bake element. try to see if the unit will get hot when set to broil. if it does then try the bake again. if you get no red hot heat from the bake element then you may need to replace it.
when an element is working properly it will heat to a red hot glow.
Jan 12, 2010 | Ovens
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Claibrating the temperature of a GE gas oven
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
Touch the Bake and Broil Hi/Lo pads
display shows SF.
Touch the Bake pad. A two digit number
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
to change the oven temperature 15°F,
touch 1 and 5.
touch the Start pad to go back to the
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGSP23 Gas Kitchen Range Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
