Question about Jazz Video Cameras
My scream is messed up
It's a little black
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Hi you nead to replace the ribbon that connects your screen to the camera as that one during the use it will break .
Posted on Feb 11, 2014
Bluetooth screams while talking on phone
Is there a hearing aid involved? Blue tooth will mess with a hearing aid.
Feb 21, 2016 | Cell Phones
Kitchen aid mixer has a scream when using dough hook.
A little pin or setscrew or key has failed. Maybe a gear has slipped out of place. Anyway, the thing needs to come apart to find out what happened. When taking things apart, line up each item off in a tidy row, put screws in little containers near the part they fit.
Repairclinic.com may have instructions, and probably have the parts.
Nov 26, 2013 | KitchenAid Food Mixers
Heat makes a screaming sound - only comes on when on high, air does not come on at all - A little advice and help needed. THANKS
The screaming sound is the blower motor bearing. the fan speed switch controls the grounding side of fan motor once on high it grounds the high speed fan relay. so lower speeds goes through blower motor resistor. this may be burnt out do to bearing is screaming tight to shaft creating a larger ampere draw that burnt it out.
Nov 13, 2013 | 1997 Chevrolet K1500
To repair car front brake cylinder
Just the tyre heating up? Have the wheel alignment checked. That screaming is because the wheel which is becoming hot is not pointing in the right direction. Perhaps you or one of your family clipped a curb or worse?
If it is the brake caliper that is heating up(sometimes accompanied by smoke rom the brakes) then you probaly have a damaged/binding piston. Repair is possible but not recommended. Dont mess with the brakes. Replace the caliper.
Jul 17, 2010 | 1996 Honda Civic
Engine cutting out intermitantly at high revs. Gets worse as engine gewts hotteR. the only coincidental is Ihave just put new rings in and it has started since then. Any Ideas - Andy
Most likely, your main jet nozzle is clogged- causing the engine to starve for fuel at high revs. Remove carb, take the bowl off the bottom and locate the main jet. The main jet is screwed into the main nozzle, which you can't see until it's removed. Remove the nozzle(brass tube with holes down sides that your slide needle goes into) and clean the nozzle and jet thoroughly. Its a good idea to do the rest of the carb the same way while you're at it. Replace the carb. If the carb adjustments haven't been messed with, this should put your little katoom back screaming again.
Jun 10, 2010 | 2002 KTM EXC 200 GS
My Camera will turn on but the display is black. I took a picture to see if the light in the display was messed up but it is taking black pictures. My husband messed with the display settings and it worked...
Reset your gadget to factory defaults........ If the problem is due to wrong settings then it will solve it. And If not, then their could be a mechanical problem so, get it serviced................
May 03, 2010 | Samsung BL103 Digital Camera
When flushed, the toilet (sounds like a lite scream)
try to replace the fluidmaster it is either that or your supply line is kinked,that or check the little black hose inside the toilet tank make sure that hose is not kinked,if neither hose is kinked replace the fluidmaster
Mar 11, 2010 | Eljer Toilet Onepiece Canterbury ...
When i turn onmy xbox it comes up with a black scream an little green moving dots i can still hear the sound !!! why this happing
Try the switch on the xbox cable and make sure it is switched to appropriate TV (TV/HDTV). Try HDMI if possible and try a different cable. If none of these work it is a GPU or Motherboard fault and may not be fixable. Good Luck
Nov 23, 2009 | Video Game Consoles & Games
Black Screen
So there's a problem with the battery or screen
Jan 07, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
Video Cameras Logo
26 people viewed this question
Top Jazz Video Cameras Experts
mohamed salim shaikh
Are you a Jazz Video Camera Expert? Answer questions, earn points and help others
